Old 12-28-2009, 03:27 PM   #1
Justen
In Too Deep
Justen's Avatar
Justen is on a distinguished road
Fuel Pressure Regulator
Just wondering if I really need and aftermarket Fuel Pressure Regulator for a Walbro pump, or should the stock FPR in the stock secondary rail be able to handle it?
Also, I know that the stock FPR has a vacuum line coming off of it, but I don't have anywhere to attach it to because I removed all of the solenoid valves when i took out all the emissions and rats nest. So i take it that the Stock FPR would not work correctly then?
Opinions? Do I need one now that my vacuum/boost solenoids are gone? Thanks
1990 TII, fresh rebuild
Atkins rebuild kit, RA apex seals
Med. Streetport, TB mod, rebuilt turbo, ported wastegate, GodSpeed FMIC
RacingBeat Turbo-back straight exhaust, Bonez test pipe, emissions/nest removed
hks intake, Walbro, Profec B spec-2
Justen is offline   Reply With Quote
Old 12-28-2009, 03:50 PM   #2
The stock FPR can handle a Walbro. You pull your vacuum source from the manifolds.
Read:
http://rotaryresurrection.com/2ndgen...s_removal.html
Specifically pay attention to this picture: (courtesy of rotaryresurrection.com)
Old 12-28-2009, 10:19 PM   #3
antman0408
antman0408's Avatar
antman0408 is on a distinguished road
My stock FPR crapped out after a couple thousand miles. I was getting 50 psi of fuel pressure all the time. I wouldn't worry about it until it does go bad, then replace it.
antman0408 is offline   Reply With Quote
Old 12-29-2009, 01:50 AM   #4
Justen
In Too Deep
Justen's Avatar
When they DO go bad, will they only let MORE pressure to be present??
...Just making sure, because I would rather not have the regulator starve the motor of fuel when it decides to fail, especially under boost
Old 12-29-2009, 07:15 PM   #5
What the FPR does, is lower the fuel pressure with more vacuum. At ide vacuum is high, and it pulls on the diaphragm in the FPR, letting more fuel flow back to the tank. When you have no vacuum, like under boost, the diaphragm restricts flow back to the tank, keeping lots of fuel in the rails, ready to go to the injectors.
While some FPR's increase fuel pressure with positive pressure on the diaphragm, I am not sure if the one on the RX-7 does so....
I have heard/seen people use an AEM adjustable FPR kit made for Hondas work on the S4 fuel pressure gegulators (has 2 bolts attaching it to the rail)
I would do some searching, and call AEM with stock fuel pressure specs, and measured frp dimensions, and ask them if they make any that would fit the rail. I have seen it done before, just cant find it...
