Old 05-06-2009, 08:22 AM   #1
Shadow24v
Shadow24v is on a distinguished road
leaky sunroof?
Well, with the recent rain, i noticed that the sunroof is leaking on my S4. is this common or is there a known fix for this?
Shadow24v is offline   Reply With Quote
Old 05-06-2009, 08:24 AM   #2
My5ABaby
My5ABaby's Avatar
There's some drain tubes on it that may be disconnected or clogged.
Community Service Manual
RotorWiki
Old 05-06-2009, 08:37 AM   #3
Shadow24v
thanks, ill look into those. esp. since the drain tubes for the back hatch were clogged when i got it
Old 05-18-2009, 08:04 PM   #4
nickbrx7
nickbrx7 is on a distinguished road
my sunroof doesnt leak but is off the track anyone know what i can do to fix it? the motor is running i can see it running through the emergency access hole but it doesnt move and i dont know how to approach this problem any ideas? thanks
nickbrx7 is offline   Reply With Quote
Old 05-18-2009, 09:23 PM   #5
Usually, if it gets to the point where you get water leaks on the ceiling, your sunroof assembly has rusted through.
This is usually caused by a plugged drain hose.
You'd be lucky to get a leaky hose or a disconnected hose as the culprit.
ANY problems with the sunroof operating requires the whole thing to be removed, rebuild / lubed, and then replaced.
This is a PITA job.
