Old 11-05-2008, 04:34 PM   #1
ArtOfRuin
Magic Spinning Triangles
ArtOfRuin's Avatar
ArtOfRuin is on a distinguished road
Strange noise from the rear wheels
I'm hearing a stange noise coming from at least the right rear of my GXL when driving (it may also be coming from the left, but I'm not sure). I assume there is something wrong with the rear brakes. The noise sounds like a flat tire, and like a flat tire it's intermittent and increases with speed. It's not a flat since the rear tires are fine and fully inflated, and the noise changes pitch when I press the brakes. It's probably related to the brakes. My best guesses are:
a) A (really) warped rotor
b) Incorrectly installed pads
The P.O. said the rear rotors are Brembo OEM type and the pads are Hawks. I'm going to e-mail him and ask for some more detail, like how long ago the pads/rotors were changed and by whom. Any help would be greatly appreciated.
'87 Mazda RX-7 GXL: Solo E Stock-bound
'98 Subaru Impreza: The Daily Beater
ArtOfRuin is offline   Reply With Quote
Old 11-05-2008, 04:39 PM   #2
Flooder
Flooder's Avatar
Flooder is on a distinguished road
Does it make the noise while you're braking? Or when you're decelerating without braking?
AZRX7.COM
Red 1991 A-package(SOLD)
Red 1990 GXL(SOLD)
White 1989 GTUs(DEAD)
Red 1988 Turbo II(DD)
Black 1988 Turbo II(SOLD)
Rebuilt and street ported motor, Garrett T04E Turbo, 3" Turbo Inlet Duct/AEM Dry Flow Filter, Your Mom's MBC, Blitz FMIC, 890cc and 1000cc injectors, Tomei FPR, Walbro, Rtek 2.1 ECU, Taurus E-Fan, Turbonetics BOV, 3" Motoria/Corksport Turbo Back Exhaust, Emissions Removed, Greddy Boost Gauge, Megan Racing Water Temp Gauge, 5one5 Triple Gauge Pod, AEM Uego, GP Sports Body Kit, Fiber Images CF Hood, S5 Seats, S5 Tails, S5 Alt, Dual Alt Pulley, D2 Coilovers, NRG Quick Release, Shook Motorsports Radiator, HID's, AN/Steel Braided Oil Cooler Lines, SUPER JDM TYTE DRIFT BUTTON
www.DensetsuMotorsports.com www.AZRX7.Com www.FloodersAdventure.com
Flooder is offline   Reply With Quote
Old 11-05-2008, 04:41 PM   #3
ArtOfRuin
ArtOfRuin's Avatar
Yes, and yes. The noise is like a flat tire- you can hear it when the car is moving, and the frequency of the noise increases with speed. The weird thing is that the noise changes pitch when I depress the brake pedal.
Old 11-05-2008, 04:43 PM   #4
any vibrations?
Old 11-05-2008, 04:44 PM   #5
ArtOfRuin
ArtOfRuin's Avatar
Very slight vibration in the brake pedal when braking, but otherwise, no vibrations.
Old 11-05-2008, 04:45 PM   #6
classicauto
crash auto?fix auto
classicauto's Avatar
Wheel bearing.
Do both
Be sure to inspect the rotors when taking it apart though as its *possible* that its something else.......but more then likely its the bearings.
Old 11-05-2008, 04:45 PM   #7
in certain gears? All gears (inc. reverse)?
Old 11-05-2008, 04:50 PM   #8
ArtOfRuin
ArtOfRuin's Avatar
Not sure. I didn't feel any when reversing, but I wasn't going very fast, either. The times I felt vibrations were at around 20-40mph in around town traffic.
Come to think of it, ClassicAuto may be right, since the car is braking OK. I'm going to check the rear brake assemblies tomorrow just in case, provided it doesn't rain.
Old 11-05-2008, 04:53 PM   #9
I'm sure this doesn't need to be said but just in case: Check first buy later. I learned that the hard way.
Old 11-05-2008, 05:13 PM   #10
SpooledupRacing
Guest
Posts: n/a
especially with the rear since those bearings need to be poressed out of the hub and spindle.
Old 11-05-2008, 05:22 PM   #11
ArtOfRuin
ArtOfRuin's Avatar
Great, replacing rear wheel bearings. This sounds like a fun job...
Old 11-05-2008, 07:00 PM   #12
Bearings!! Yay fun!!
You can get a special bearing puller/installer that allows you to do it with rear spindles in place. They can be spendy, but for me...its worth it since they work on MANY other cars (your friends will thank you).
Old 11-05-2008, 08:12 PM   #13
RoughRex
Out of Nickels and Dimes
RoughRex's Avatar
check your axles out too while your back there. I just encountered this same issue on the right rear of my GXL... some vibration during driving/braking accompanied by a thrumming noise from the rear of the car. I inspected the rear and I noticed that the Right rear outer boot on my axle has aparently split open and is now splattering grease all over as I drive... this could be a result of some other issue but... I bought a used axle yesterday just in case. So DJ...you have a tool to pull that bearing do ya....
1988 GXL
Old 11-05-2008, 09:43 PM   #14
ArtOfRuin
ArtOfRuin's Avatar
Axles, too? Boy, did I pick a winner... Well, tomorrow I'm going to get my FC's oil and belts changed (would do it myself if it wasn't going to rain all this week. I hate not having a garage). When it goes up on the lift, I'll take a look and see what I can find back there.
Old 11-06-2008, 04:18 PM   #15
ArtOfRuin
ArtOfRuin's Avatar
I couldn't get the car up on the lift today or check out the rear brake assembiles due to the rain, but the noise now only occurs during braking. There's no vibrations, either.
