Old 10-01-2008, 04:37 PM   #1
impulsive-RX7
impulsive-RX7's Avatar
impulsive-RX7 is on a distinguished road
WTB Driveshaft for '83 GSL, ship to 28546
I need a driveshaft to go with my GSL rearend swap. 83 model year. Good u-joints please.
impulsive-RX7 is offline   Reply With Quote
Old 10-01-2008, 08:12 PM   #2
whitey85mtu
whitey85mtu is on a distinguished road
I have a S3 driveshaft with only 92k miles on it. pm me.
whitey85mtu is offline   Reply With Quote
Old 10-02-2008, 11:59 AM   #3
impulsive-RX7
Is the S3 flange same as the '83? http://www.mazdatrix.com/g5.htm
Old 10-02-2008, 02:03 PM   #4
P71
P71's Avatar
No, it is not. I just went through all this jazz with my 83. U-joints in S1/S2 driveshaft are not replaceable. They are in S3. S3 driveshaft uses a different rear diff flange and bolt pattern. You cannot modify the 83's to work.
Michael Pinto
Read my Rx-7 Build Thread!
Vote for the ROTM!
Old 10-02-2008, 02:20 PM   #5
Rogue_Wulff
Non Member
Just the opposite. S1/S2 have replacable ujoints, while S3 does not. However, the 83 can have either setup, from the factory. According to the parts micro-fiche, all 83's have the larger flange and non-sevicable ujoints, but some early 83's had the same setup as the 79-82.
Easy way to tell which flange you have. The large flange has 4 holes, none are threaded and is a square pattern, while the small flange has 4 threaded holes, but is not square.
Last edited by Rogue_Wulff; 10-02-2008 at 05:31 PM. Reason: spelling error, need new keyboard.....
Old 10-02-2008, 03:30 PM   #6
P71
P71's Avatar
Ah, thanks for the correction. I knew it was one way or the other with the 83 sandwiched in the middle. Mine had the S3 style on it and I swapped back to the replaceables.
Michael Pinto
Vote for the ROTM!
Old 10-02-2008, 05:59 PM   #7
impulsive-RX7
Yes my dear '82 driveshaft that I just recently had new u-joints put on.. I guess I should double check to see if it fits the 83 rearend that I just installed.
Old 10-02-2008, 06:40 PM   #8
P71
P71's Avatar
If not just grab a new flange and use your 82 DS.
Michael Pinto
Vote for the ROTM!
Old 10-03-2008, 06:32 AM   #9
$100T2
Big Daddy
$100T2's Avatar
Will a driveshaft from an 84 work? I think I have one.
Old 10-03-2008, 11:49 AM   #10
Rogue_Wulff
Non Member
Since his 82 DS doesn't seem to fit, then the 84 DS should work, as long as it wasn't from an auto equipped car. 84/85 auto's were longer than 79-83 auto and all 5 speed trans.
Old 10-16-2008, 03:21 PM   #11
impulsive-RX7
So, yes I confirmed that I indeed need the driveshaft with the larger bolt pattern. I offer 50 bucks shipped plus beer if you ever come to visit.
Old 10-18-2008, 05:36 PM   #12
impulsive-RX7
Nevermind, I did not find one locally.
