Old 09-13-2008, 10:14 PM   #1
maui_boi
FC Rotary Power
maui_boi is on a distinguished road
my car starts but runs poorly
my car starts up and everything but dosent keep idle and when i drive it it starts to bog and loss power at 4000rpm anybody got suggestions
maui_boi is offline   Reply With Quote
Old 09-13-2008, 10:27 PM   #2
Polito Racing
so you got pistons oh wow
Polito Racing's Avatar
Polito Racing is on a distinguished road
what kind of car is it? does it have any modifications? what exactly is it doing? the idle thing could be a loose vaccum. About the 4000 rpm it sounds like a transition problem since its happening arround where the secondaries kick in. my advices are check your compression on the engine and make sure you have compression on all faces on both rotors, check all your vaccum hoses and get you some starting fluid and carefully and without loosing your eyebrows!!! spray it arround your engine to check for leaks. You will know where the leak is at because the acceleration in the engine will change and run some nice thick ground cables from the shock towers to your engine to see if this help with your hessitation problem. not sure if available on this forum but do a search for 3500rpm hessitation and you'll find what your looking for.
Good luck
Polito Racing
2000 F-350 SD (Daily Driver)
2002 CBR 954RR (Back on the Road)
1987 RX-7 Turbo II(red bullet!!)
Polito Racing is offline   Reply With Quote
Old 09-13-2008, 10:52 PM   #3
+1^^^
mileage?
When was your last tune up?
How old are the spark plugs?
TPS within specs?
http://www.rotarycarclub.com/showthr...service+manual
Old 09-14-2008, 01:58 AM   #4
maui_boi
FC Rotary Power
the car is a 88 n/a with 93k miles we just changed the plugs and the car starts up fine its just dosent want to stay idle when first started it stays after a while of running. for the 4000rpm part it sputters and starts to bog out but still goes and picks up rpm slow like just sputtering and stuff i dunno how to xplain it maybe if i can ill post a video or sound or something to let u guys know if i know how lol
Old 09-14-2008, 02:05 AM   #5
Tps?
Old 09-14-2008, 08:42 AM   #6
did you look into the condition of the injectors?
Old 09-14-2008, 01:24 PM   #7
maui_boi
FC Rotary Power
not yet but also where is the secondary injectors i dunno where they are or to check it
Old 09-14-2008, 01:39 PM   #8
did you check the FSM? They're on the top-most rail:
http://foxed.ca/rx7manual/manuals/19...SYSTEMS_NA.pdf
Time to get to work. Let us know what you find out.
Old 09-14-2008, 02:07 PM   #9
maui_boi
FC Rotary Power
where is the TPS
Old 09-14-2008, 02:32 PM   #10
+1, check your injectors and get them shipped out to be clean.
Old 09-14-2008, 02:45 PM   #11
maui_boi
FC Rotary Power
but where can i find and check the secondary injectors so i can just get em all one time
Old 09-14-2008, 02:57 PM   #12
Secondary injectors are located on the top of the first bend on the Upper intake manifold. The two injectors located on the outer edges of the runners.
The primaries are buried under the UIM and the UIM will need to be removed for you to gain access to them. Happy hunting!
Old 09-14-2008, 03:03 PM   #13
maui_boi
FC Rotary Power
so the secondarys are on top and the primary is underneath?? on the n/a right?
Old 09-14-2008, 03:24 PM   #14
yup
Old 09-14-2008, 08:10 PM   #15
maui_boi
FC Rotary Power
k i checked all of it and they work and i disconnected the TPS and it idled good just still getting that bad runing at and after 4000rpm
