Old 08-10-2008, 01:58 PM   #1
hIGGI
hIGGI is on a distinguished road
possible S5 TII OMP problem
S5 TII, fresh rebuild
car runs like shit when u try to load it up a little bit, which seems to be OMP problem....i checked resistance on 6pin connector and there is none, assuming OMP is really bad....
question is : can i use some resistors and 'cheat' stock ECU to run ok without OMP or is my only solution to find some good OMP?
hIGGI is offline   Reply With Quote
Old 08-10-2008, 02:51 PM   #2
I looked at the specs for both the NA and TII oil pumps and here are the differences:
NA pump diameter x width of rotor: 50mm x 17.5mm
TII pump diameter x width of rotor: 50mm x 12.5mm
You may have a hard time using an NA OMP pump if you look to replace it. Let me know if you want to trick the ECU or get aa new OMP.
Old 08-11-2008, 07:46 AM   #3
Boostmaniac
This problem just doesn't sound right. Do you have any more info on the engine?
Old 08-13-2008, 12:56 AM   #4
hIGGI
I am talking about OMP, not oil pump.....
Old 08-13-2008, 01:00 AM   #5
hIGGI
I have built engine and everything else in test came ok. I had same car (with no problems) sitting next to this one and i checked and compared everything, replaced fuel pump, afm, boost sensor, measured tps etc...)
Last thing i tried was unhooking OMP on working car and it started to behave exactly same like car with problem. Then i measured resistance/voltage on OMP of working car and on other car as well - working car had good results, problem car none. Thats the point where i found OMP (or its wiring) to be faulty and thats why it goes into limp mode. With some luck, i might get working S5 OMP from friend today and will hook it up friday to see if its all whats wrong...
Will let u know
Old 08-13-2008, 01:02 AM   #6
Old 08-15-2008, 12:34 AM   #7
hIGGI
have spare OMP from friend, will try to hook it up today and let u know results.....
Old 08-15-2008, 04:57 AM   #8
You cannot fool the stock ECU unless you get a microcontroller.
The problem is that there's a feedback circuit which tells the stock ECU what position the stepper motor is in.
This is the big problem.
It's easy to fool the stock ECU into "seeing" the 3 stepper motors (via resistors), but how do you fool the feedback circuit?
Old 08-17-2008, 02:10 PM   #9
hIGGI
Replaced OMP today, problem fixed....
Old 08-17-2008, 07:52 PM   #10
well, you can either:
A: Buy the RTEK S5 omp canelling chip for $100, then get a S5 OMP block off plate, gasket, and RTV to seal it..
or,
B: Get another used S5 OMP, and refurbish the lines courtesy of a guide on the evil forum.
