#1 | |
Are S4 and S5 Turbine Wheels Interchangable?
Wanting to know if I can put a S4 Turbine Wheel and Shaft in a S5 Turbine Housing and center section?
Yes.
Turbos are identical: compressor wheel compressor housing turbine wheel center housing Basically, the entire CHRA is the same. NOT the same: turbine housing oil drain pipe -Ted |
#3 | |
Ok Ted, thanks. I figured you would have the answer
I just bought eriksseven's old TO4B Hybrid and the shop doing the balancing told me the compressor wheel and shaft were damaged and he is unable to balance ........ So I guess I will need another compressor wheel and maybe I can reuse my stock S4 shaft and turbine I have laying at the house.
