Old 04-16-2008, 02:37 AM   #1
IGNITION PROBLEM: Arcing L2 Sparkplug
Well I asked on the other club a while back and didn't get much help and the problem was never fixed.
Backstory: Visible current on the outside of the sparkplug on my friend's vert. He replaced wires, plugs, and the problem is down to the L2 sparkplug. The Leading plug of the second rotor was ARCING badly. Now it's stumbling too.
Well he has been working on it all day and decided to use the LED ECU CODE CHECKER to see if it was throwing any codes.
None.
We checked his timing and it was way off so it was brought back to specs. It was still stumbling and we weren't expecting the arcing to stop which we believe might be causing the stumbling.
Next he decided to test the coils. We checked the FSM and it tells you to do a voltage test to make sure the coils were getting plenty of power. Did Steps 1-3 and read the warning about causing damage if you do not unplug the battery before removing the voltmeter probes.
It tested at 14.4V.
FSM SPECS: 12V
OK, so the coils are getting pumped with 14V and causing the arcing?
Maybe a ground?
Well I found a nice article on team FC3S.org about the ignition system A GREAT READ!
Well, it got me thinking that we might as well eliminate the CAS as a possible cause of the ignition issues. Well the FSM says that the G1 and G2 signal should be between 110Ω–210Ω and the same for the NE1 and NE2. Well the CAS is coming at 168 and 168.5 respectively.
It's fine electrically. tomorrow we're going to pull it out and make sure it's set properly and recheck the timing and keep tracking down the problem.
Any thoughts or input would be greatly appreciated.
KEYWORDS: FSM, FSM*, LED, CODE, CHECKER, ARC, ARCING, SPARK, PLUG, LEADING, COIL, CAS, CAS*, STUMBLING, MISSING, TIMING
Old 04-16-2008, 11:05 AM   #2
What kind of wires?
What kind of plugs? NGK BUR's I assume?
Old 04-16-2008, 12:15 PM   #3
yup, NGKs.
Old 04-16-2008, 12:54 PM   #4
Ender
rotors excite me
Ender's Avatar
Did you check the resistance on your plug wires? It's best just to make sure... This one has me confused, I had the same problem, but it was fixed with new plug wires.
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 04-16-2008, 01:06 PM   #5
they're new NGKs so I didn't bother, I'll check them today.
Old 04-16-2008, 02:27 PM   #6
Kentetsu
Kentetsu's Avatar
It sounds like you've covered everything other than engine grounding. Might want to run a temporary ground to the motor just to see if it makes a difference...
Old 04-16-2008, 02:28 PM   #7
That's what Higgi was recommending I do also. I'll keep updating and adding pics if I find anything.
Old 04-16-2008, 03:08 PM   #8
Apac tii
Apac tii's Avatar
Apac tii is on a distinguished road
Check to make sure your grounds are good this could be your issue.
1988 Mazda RX-7 T2(list of mods here)
http://designengineeringworks.com/project_cars.php
2004 Saturn Ion Redline(dd)
1999 Mitsubishi Galant V6(the backup beater)
Apac tii is offline   Reply With Quote
Old 04-16-2008, 03:17 PM   #9
I'll definitely do this before pulling anything else apart.
Old 05-01-2008, 11:34 PM   #10
Damn,... did this ever get fixed? Sounds dangerous, and reminds me of when I let my car run for like 10min with a spark plug wire disconnected!
Old 05-02-2008, 12:21 AM   #11
No, he just drives the van. He's pretty busy and doesn't work on the FC very often, only when he has free time.
Old 05-08-2008, 04:45 AM   #12
JunpoweR
JunpoweR is an unknown quantity at this point
It could also just be the wires.
Try another set or ground everything always fixes everything.
I hear of that problem happening sometimes with cheap wires and sometimes Magnecore do that also.
Never ever happened to me tho.
--^v--JunpoweR--^v--
"90 GTUs Crystal White *GT35 WB TA Project*
"90 GTUs Brilliant Black *Restoration*
1984 GSL-SE *Daily*
JunpoweR is offline   Reply With Quote
Old 05-08-2008, 01:44 PM   #13
I dunno, I haven't talked to him about his car in a while. He replaced the wires and plugs with NGK so I dunno.
Old 05-08-2008, 01:55 PM   #14
TehMonkay
Did you check that the threads were clean in the housing? I dont know how much of an impact that would have but it's worth checking.
Old 05-16-2008, 09:33 PM   #15
well, he says it's a bad ground so he's getting that fixed right now. He's thinking of selling it after it's fixed so he can finish his TII instead of upgrading the vert.
