Old 05-28-2016, 01:09 PM   #1
Gano56
Gano56 is on a distinguished road
87 rx-7 non turbo
Alright guy I'm young bought the car 1-2 weeks ago. Its bridgeported motor has a omp delete. I'm using marine 2-cycle TC-W3 outboard engine oil in my gas tank every Time I fill up a ounce a gallon. Now it's time for my first oil change what I found in the hatch is a Pennzoil Marine 2cycle synthetic blend engine oil tc-w3 Is it okay if I use that assuming that's what in the car already Also filter suggestion? there probably thread which I can not find for this but I want the correct answer told to me
Gano56 is offline   Reply With Quote
Old 05-28-2016, 06:55 PM   #2
Dannobre
Dannobre is on a distinguished road
The 2 stroke oil is for the gas
I use 15-40 in mine
Dannobre is offline   Reply With Quote
Old 05-28-2016, 07:47 PM   #3
Yes, the 2-stroke oil is for premixing with gasoline.
Use "regular" motor oil for the engine...
I recommend 15W40 (usually labelled for "diesel engines," but it's good for your engine due to added detergents) or 20W50.
The higher weight oils are good for your rotary since the thicker oil is better for protection.
Most of us do not worry about gas mileage...
Old 05-28-2016, 08:14 PM   #4
almoststockfc
almoststockfc's Avatar
Synthetic is always better. The weight depends on what your environment is and where you live.
-75 RE_W_PU -
Old 05-29-2016, 04:40 AM   #5
Gano56
Apperiate the help guys tomorrow I'll probably go ahead and buy 20w50 I been hearing that oil grade come up a lot in my research on oils. I live in Texas temperature always super hot.
Old 05-29-2016, 03:47 PM   #6
chibikougan
chibikougan's Avatar
http://foxed.ca/index.php?page=rx7manual#firstgen
