|  04-18-2008, 03:13 PM | #1 |
| Sigh..... Join Date: Feb 2008 Location: Murfreesboro, TN
				Rep Power: 20  |
				Suspension kits
			Ok, I'm redoing my subframe/suspension area (rubber, bushing, etc.) and I'm curious about some things.  Basically, I need all the rubber and ordering it through Mazda is expensive as hell.  I've looked at kits such as Energy Suspension but I'm not sure which pieces they can be substituted for.   Mazdatrix has quite a few kits (which I've emailed them about and have yet to hear back). Anti-Sway Bar Bushing Sets - One set needed to fit the Front bar. 24mm bar only. - One set needed to fit Rear bar (14mm bar only) Front or Rear Sway-Bar End Link Bushings These are pressed into the stock links (86-88 only) to replace the factory rubber bushings. One set needed per end of car. Front Lower Control Arm Bushing Kit (86-92) This is a really good kit that contains the bushings needed for the front and the rear pivots of the front control arm. The inner diameter has the "barb" shape to conform to the OEM arm. Complete with the needed steel sleeves and bushings to do both arms. - Front Lower Control Arm Bushing Kit - Front Lower Control Arm Bracket Rear Lower Control Arm Bushing Kit This kit does the front pivots of the rear lower swing arm. Complete with bushings and sleeves to do both arms. HYPER-FLEX SYSTEM Complete Master Bushing Set (Energy Suspension): - Front and rear control arm bushings - Front and rear sway bar bushings - Ball joint boots - Tie rod end boots Here's the list of what I'm wanting: Rear Suspension Stopper-Rear Damper Rubber 2 FB01-28-014 Spring Rear Damper Sheet 2 FB01-28-040 Mounting-Rear Damper Plate 2 FB01-28-050 Rear Damper Stopper 2 FB01-28-030A Rubber-Rear Damper Bushing 2 F044-28-015 Rubber-Rear Damper Bushing 2 F044-28-013 Rear Damper Plate Set 2 FB01-28-020 Rear Damper Spacer 2 FB01-28-025 Rear Stabilizer Stabilizer Rear Bushing 2 FB43-28-156A Rear Lower Arms & Sub-Frame Rubber-Rear Lower Arm Bushing 2 FB01-26-220 Pillow-Rear Lower Arm Ball 2 FB01-26-230 Seal-Rear Lower Arm Rubber 4 FB01-26-250 Lower Arm Bushing 4 FB01-28-460 Sub-Frame Rubber 2 FB43-28-840 Mounting-Differential Rubber 2 FB01-28-890C Rear Axle Lower Arm Stopper 2 FB01-26-335 Seat-Bearing Housing Rubber 2 FC01-26-410 Front Suspension Mechanisms (1-M13) Stop Bumper (Bound Bumper) 2 FB01-34-111A Spring Cushion (Rubber Sheet) 2 FB01-34-012 Spring Seat 2 FB01-34-341 Damper Cap 2 FB01-34-019 Rubber Lower Arm Bushing 2 FB01-34-460 Rubber Front Bushing 2 FB01-34-470 Crossmember and Stabilizer (1-D14) Stabilizer-Front Rubber 2 FB43-34-156 Differential Mounting-Differential Casing Rubber 2 FC01-28-980 Front
				__________________ 1986 Sport: 132k miles, 5A (Sapphire Blue Metallic), Tokico Blues, Racing Beat Springs, Custom LED tailights (only S4 LED tails in the world), SSR Mark II, Racing Beat exhaust, S5 black interior, Rotary Resurrection rebuild at 120k miles Community Service Manual RotorWiki "Imagination costs nothing; we could build square locomotives or fly to Mars" - Felix Wankel Yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the "present." |
|  04-18-2008, 04:47 PM | #2 |
| Out of Nickels and Dimes Join Date: Mar 2008 Location: Nashville, TN
				Rep Power: 18  |
			Are you really gonna make us look at the FSM so we can understand that? :P   When I did my suspension I bought the springs(eibach), sways(eibach), strut top mounts(Tokico), and struts(Tokico HP) off of ebay. I got the rest of the small rubber parts from the dealer except for the boots which I got from some other web vendor. I also got the front and rear control arm bushings(energy) off of ebay and I got all my drivetrain mounts from Ray Crowe at Malloy Mazda. Those were the cheapest places I could find to get those parts, I hope that helps.
				__________________ 1988 GXL |
|  04-18-2008, 05:30 PM | #3 |
| My minds tellin' me no... Join Date: Feb 2008 Location: Murfreesboro, TN
				Rep Power: 22  |
			You already have a thread just like this. Thread closed.
				__________________ 1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5 |
