| Introduce yourself!! Tell me something about you and your history with rotary.. |
Hello everyone
My name is Alex Rodriguez same one from rx7club I drive
93 FD- track car/show car /weekend driver 86 FC- daily driver 87 FC- time attack build 08 m3-daily to daily driver lol ![]() ![]()
My FD3s mod list is as follows
Suspension----- Stance GR+3w/External reservoirs Suspension Techniques front sway bar Racing Beat front lower swaybar mount brace Engine Large streetport ,ALS seals, Atkins solid corners, full Mazda OEM spring and seals kit, Rotary Aviation coolant seals,orings and oil control seals. Silicone vacuum hose conversion OMP delete kit including drive gear for less strain in front assembly M2 Performance lightweight aluminum flywheel B and M short throw shifter ACT HD PP +6 PUC New pilot bearing and seal Turbo----- Garrett TO4z gt35r compressor wheel .70a/r compressor 4” diameter compressor inlet .96 hotside polished compressor HKS 304 stainless exhaust manifold Tial 40mm wastegate 1.0 bar spring HKS blowoff valve Custom engine compartment turbo heat shields Custom intercooler system made By GARRETT 12 x 18 x 3” (H/W/T) Garrett core w/ custom fin sets Slant mounted (for max size, space, and performance) Custom cold-side air ducting using original factory air supply duct Custom sheetmetal end tanks 2.5” intercooler plumbing 12” Spal draw-through fan Custom cold air intake system Sealed aluminum airbox w/ DEI reflecta gold Nose/under-car air source K&N cone filter (6” max diameter) 4” duct from air box to compressor inlet Custom oil cooler system Dual 19-row Setrab oil coolers Mocal oil thermostat -10AN SS braided lines and fittings Parallel plumbing configuration (for max effectiveness and min pressure drop) Mazdaspeed oil cap Rotary13b1 brake cap Cooling system------- MazdaComp aluminum race radiator 185º thermostat FC thermoswitch (changes fan switching temp from 226 to 203F) Auxiliary electric cooling pump (to prevent hot shutdown heat soak) Air separation tank (AST) removed Cooling fan relays rewired to eliminate low speed operation 4 vent carbon fiber Knightsports extractor hood (to reduce underhood temps) Greddy water pump underdrive pulley (to prevent high speed cavitation) AC system removed DEI reflect -a-gold on intake box, radiator,and lim uim Custom exhaust---- 3” v-band downpipe (w/ shielded flex section open dump pipe) 3"to 4" stepper TRUST 4" mid pipe Rare!!! TRUST 4" MID PIPE BACK Super mega exhaust TRUST V-band-clamp connections MANAGEMENT----- APEXI power FC APEXI commander LS2X YUKON coils with individual built in igniters Fuel Cj motorsports primary rail Rx7store secondary rail with fuel temp bung Bosch 1680 cc secondaries Injector dynamic 1000cc primaries Aeromotive FPR Summit Racing -8AN 40 micron filter Summit racing fuel gauge JEGs y-block Russell Y-block BOSCH 044 in tanks -8 FEED nylon braid lines with all hardended fittings Brakes----- Brembo front rotors Goodridge SS braided lines Motul 600 fluid Hawk Blue pads (track only) ABS- Delet kit - earl/xrp fittings in braided lines SSBC proportioning valve Gauges Prosport boost gauge Prosport oil pressure gauge Prosport water temp gauge Prosport 60mm triple center pod INNOVATE Timer wideband AFR w/digital display and datalog to TEC3 INNOVATE LC-1WIDEBAND LAMBDA HKS turbo Timer Afc hand held Other----- Magnecor 8.5mm plug wires with MSD ls boot ends Bosch battery relocated behind passenger in storage bin Custom hidden trailer hitch (used to tow race tires to track) Greddy alternator pulley Greddy underdrive pulley Greddy water pump pulley Custom aluminum catch can Greddy aluminum intake elbow INTERIOR RECARO Spirit R seats recaro reclining seat rails AUTOPOWER 6 point cage MOMO veloce 20yr old vintage race wheel with RARE red Horn miata wheel hub NRG quick release FULL BLACK INTERIOR CONVERSION broadway mirror glass sunroof 3 over ride switches for external water pump, radiator fan, intercooler fan Pioneer avic 1double din Kicker DS 6x8 mids Kicker DS Tweeters Kicker DS crossover, Alpine small 1000watt amp JL audio w6 10" subwoofer Custom Fiberglass enclosure built by me JDM arm rest TRUST shift knob EXTERIOR--- VERTEX bumper VERTEX side skirts RE Amemiya rear CARBON track Diffuser RE Amemiya gt3 wing Knight Sports vent hood Uras turn signals Converted 99 tails 4 prong LED bulbs Glass sunroof RE Amemiya sleek lights,evo r 90 mm HIDs WHEELS- Work Equip 18x10 +22 Front 18x11 +22 Rear TOYO R888 race tires 285-30-18 255-35-18 Project KIcs r22 lug nuts ] |
Rep Power: 20 ![]() |
Welcome buddy! Glad to see you made it over here. It's Eric by the way. I didn't realize you had two FCs also.
Yooooo lol yup actually 4
Hi.
13B-RE Full Bridged....and a few other mods |
4 FCs or 4 RX-7s total? lol
7Club Refugee
Rep Power: 15 ![]() |
Hi
Does the Avitar look familiar?
"he's a tool that moved from being an abusive moderator to a troll that acts like a tool to get his attention now." John (Jon) Michael Borry = RX7roller02 = skydivr7673 And that's the truth. http://rotarycarclub.com/rotary_foru...t=17659&page=7
#9 |
Professional Stick Poker
Welcome Alex. Dang, have you got any mods you haven't done yet?
My one 1stGen is enough to drive me slightly batty, but 4 RX-7s?
#10 |
rotaryevolution.net
sup Alex.
http://rotaryevolution.net |
#11 |
Get off my lawn!!!
I think you guys are about a year late to the party
'94 Touring - Cursed '96 NA Miata '14 Mazda3 Hatch '14 Aprilia RSV4 R |
#12 |
Party pooper. Now I feels stoopid for not checking the thread date. The deleted pictures should have tipped me off.
Oh well, welcome anyway Alex, wherever you are.
#13 |
Administrator
Rep Power: 10 ![]() |
I took a great photo of him on the track at 7Stock last year.
Kevin
#14 |
500hp club
Nice looking car
500hp AEM EMS RotaryAutomotive street ported Aviation sealed 13b-rew 20B 20BEEST FD 23A 4 rotor Long gone 72 rx3 drag machine |
#15 |
Woot wooot
