Old 04-14-2009, 10:30 AM   #1
My5ABaby
My5ABaby's Avatar
S4 LED Taillights Finished - Worlds First?
Here's the project I've been working on that will debut at DGRR. Pictures is only the stop lights lit up, but I also did the turn signals. I'll get a picture of those later.
Due to the auto exposure the third brake light doesn't show well but it's two rows of 8 LEDs.
My next task, if possible, is to get rid of the reflector and put it somewhere else (reverse light area).
The second picture I messed with in Photoshop to show the individual LEDs more clearly.
Partial picture of the wiring. I spliced in probably 20 wires into the existing harness.
Community Service Manual
RotorWiki
Old 04-14-2009, 10:34 AM   #2
My5ABaby
My5ABaby's Avatar
Also, there are ~60 LEDs per section (excluding the 3rd brake light of course).
--- Post also reserved for more pictures ---
RotorWiki
Old 04-14-2009, 10:39 AM   #3
That's pretty cool, did you do the boards yourself?
Old 04-14-2009, 10:45 AM   #4
My5ABaby
My5ABaby's Avatar
Basically everything is custom. The only thing that could be considered premade are the PWM (Pulse Width Modulators) seen in the third picture (green things with all the wires run to it). The circuit boards for those were made/designed by someone else and I installed all the parts onto them. Otherwise, every LED, wire, resistor, etc. was installed by me onto blank circuit boards.
To avoid confusion, the PWM are used for dimming. They turn on and off the LEDs numerous times per second which is unnoticable to the naked eye, but does create a dimming effect. I use them for the running lights.
Here's one of the boards pre-cutting.
RotorWiki
Old 04-14-2009, 11:03 AM   #5
RoughRex
Out of Nickels and Dimes
RoughRex's Avatar
Nice work, Can't wait to see how they look in person
1988 GXL
Old 04-14-2009, 11:11 AM   #6
Looks pretty cool, I may have to keep my S4 Tails so I can do that sometime.
Old 04-14-2009, 11:34 AM   #7
My5ABaby
My5ABaby's Avatar
It took quite a bit of time. I'd say I put in at least 60 hours on the project. I won't even talk about cost... They're basically untested so hopefully nothing will go wrong (at least until after DGRR).
RotorWiki
Old 04-14-2009, 12:18 PM   #8
WOW! Pretty cool! You need to show us what it takes to do them I thought about doing this for my FD.. Some day..
Old 04-14-2009, 12:25 PM   #9
PercentSevenC
Custom User Title
PercentSevenC's Avatar
That, my friend, looks sick.
I actually prefer the S4 tails, and this looks like a great way to "modernize" them.
Old 04-14-2009, 12:28 PM   #10
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
Imagine that in S5 tail lights. :drool:
Old 04-14-2009, 12:30 PM   #11
My5ABaby
My5ABaby's Avatar
Thanks.
I'm contemplating on offering a retrofit service. However, I'll likely not do it and, if not, will try to do a write up. It would be for an S4, but the process will be similar for other models.
I have seen several S5 retros, but no S4. All of the S5 I have seen do a single circle of roughly 20 LEDs.
RotorWiki
Old 04-14-2009, 11:41 PM   #12
Rotary#10
Rotorhead
Rotary#10's Avatar
2 thumbs for you work and creativity... Looks very cool!!
Currently running:
90 N/A GTUs..
Running project car
89 N/A GTUs in Black #2
10/6/18
Old 04-14-2009, 11:59 PM   #13
My5ABaby
My5ABaby's Avatar
Thanks. I need to get up turn signal pics to bring it all together. My next step is finishing the reverse lights. Im going to run at least 60 LEDs per side putting out 10ish lumens each. Depending on how bright that is I might bump it up to 100 per side.
RotorWiki
Old 04-15-2009, 04:26 PM   #14
yeti
yeti is on a distinguished road
Nice. I'm planning on doing my s5 tails one day.. Anyway I'd be willing to invest in your business if you plan on selling.
1989 vert, RB header and presilencer (looking for a catback), SAFC-II, custom fiberglass speakerbox, 130 amp alternator sweetness.
Parts Interchangeability List
yeti is offline   Reply With Quote
Old 04-15-2009, 04:52 PM   #15
Ok, a few important questions:
1. What's the output per LED?
2. How much current are you running to them?
3. What's the light spread look like?
I wanna see a wall lit up by the lights please!
Great job on the mod for sure, it look less like an EG from behind!
