View Poll Results: What should I do?
Find an new OEM tank 0 0%
Have the old tank cleaned and coated 2 100.00%
Replace the tank with a certified fuel cell 0 0%
Give it up, take up knitting or join a book club 0 0%
Voters: 2. You may not vote on this poll
Old 12-10-2012, 01:05 PM   #1
magpiemini
magpiemini's Avatar
magpiemini is on a distinguished road
Gas Tank HELP !!
1984 RX7 GSL-SE (Fuel Injected)
After a couple of track days and months of prep I finally got this LeMons project into a race. Car has been running like a bat out of hell but three laps into the race it died, fuel pump stopped. Took it out hooked it up to 12v and it was dead for sure. Found something with enough pressure and volume, replaced the filter and it ran for three laps, sputtered and died. The fuel tank has begun to disintegrate, varnish and all kinds of black crap, plugs up a filter in no time. Yes, we checked the damn relay, do not get into that, just a waste of time.
So, I have been searching the web for a few hours looking for a new tank, can't find one. I would like a new one but I suppose I could use a cleaning and coating kit, or have a pro do it for me.
The 24 Hours of LeMons prefers OEM style tanks and placement but I also could spend the bucks for a certified fuel cell.
Ok, now is the time for all your opinions on tanks and fuel pumps. I will probably be setting it up with a large FRAM fuel filter with with replaceable cartridges.
1984 RX7 GSL-SE
Building for the 24 Hours Of Lemons
magpiemini is offline   Reply With Quote
Old 12-10-2012, 01:09 PM   #2
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
My opinion is go with the fuel cell even if it's not required. Had a family friend that died from burns when his car went up in flames on the racetrack. Your life is not worth saving a couple of bucks.
Old 12-10-2012, 03:48 PM   #3
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
No new tanks, refurb or replace with another used one. Or go fuel cell.
Old 12-12-2012, 08:08 AM   #4
eprx7
eprx7 is on a distinguished road
Just buy a fuel cell the rx7 fuel tank is exposed to much if you get rearended you may go up in flames. I know a fuel cell is big money but its a lot safer.
1979 SA F Prepared solo/ Track day car 12a w/Weber carb,RB header and exhaust,
Ground Control coilovers, camber/caster plates
GforceEng.panhard rod w/ tri-link,Panasports wheels w/Hoosier slicks.
eprx7 is offline   Reply With Quote
Old 12-12-2012, 09:33 AM   #5
DO NOT have the tank coated... I spent a full year fighting clogged fuel filters and one wiped out a engine on the dyno from a coating that was melting from the increased ethanol content.
Fuel Cell......
Or do what I did, I built my own which houses and in tank surge tank.
