Go Back   Rotary Car Club > Introduction > How To Use The Forum
How To Use The Forum If you have questions about how to use this forum or any of it's features please post them here!
Old 02-19-2013, 12:47 AM   #1
drag_on
drag_on is on a distinguished road
Exclamation Help!
So the story is, my friend wanted to install a double din in my car, 93 rx7. We ended up taking all the panels off and pulled back the cluster, to end up finding out we didn't have to do that period. Well we pulled out the stock CD player and was about to remove the stock radio, but couldn't get out hands on the harness and didn't want to rip any wires. So we put very thing back together.. I checked the vehicle to see if everything was working properly. Everything was fine.. Did all my headlight and turn signal and hazards light. Then it took a dump on me. I cannot turn on my head light and hazard doesn't work. I can press the button to make the head light pop up and the high beam will work but not the regular light, turn signal or hazard. Please help
drag_on is offline   Reply With Quote
Old 03-30-2013, 07:34 PM   #2
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
check the fuses first, may have pinched a wire in the controlling circuit. although the headlight switch is on the column so... check the wiring around the steering column under the dash for any pinched wires.
