Old 09-13-2011, 05:44 PM   #1
sgt.stinkfist
sgt.stinkfist is on a distinguished road
is my ECU bad?
long story short, my car has being developing a dead/1 rotor mis at random, happens mostly on light throttle and sometimes at idle, revs fine and accels fine through WOT. i scoped my injector signals at the ecu, and when the mis happens the front primary injector signal drops out completely, while the rear is operating fine. when i snap the throttle, the front injector starts working again.
the wiring is ok, as i tested and rewired the harness to fit in an FB chassis. 12v at all injector clips and >.1 ohm resistance from the clips to the ECU plug.
the ECU is an N326...
could my ECU have a bad injector driver? or is there some other sensory input to my ECU that i dont know of, that is making it drop the primary injector?
82 GS- GSL rearend, ported S4 13b, MSD 6AL, walbro 255, 460/550cc injectors, 2" dual exhaust, 3 row aluminum radiator w/ taurus E-fan
85 20v ST AE86 - sold to fund the 82
86 RX-7 GXL - donating parts to the 82
everything else - scrapped to fund the 82
sgt.stinkfist is offline   Reply With Quote
