Old 09-28-2010, 06:27 PM   #1
R1_Stormrider
Traveling in Stygian
R1_Stormrider's Avatar
R1_Stormrider is on a distinguished road
near death experience. riddle me this batman!
well heres the story and what happened. i boosted the car around the city for a bit and before takin it back to the shop something happened. all of a sudden the whole car turned off. kinda like flipping a light switch in your room. i had just come out of a pull at 15psi as well.
so i figured i would straighten the car and coast to a stop. well here is the punchline everyone, the steering wheel clicked to the lock position as if i was parked with the key out of the ignition. yes, the key was forward and since the lock is mechanical i have no idea why this happened.
so i immediately gave up toyin with the wheel since a marble sign was coming right at me. instead i hit the brakes and did 180 to stop the car with the hand brake. no damages everything good.
here's what ive done:
-i have checked every single ground on the car that i could think of
-checked the kill switch in my battery compartment (its in the bin behind passenger seat)
-checked all fuses
-rattled all grounds while idling the car with headlights/stereo on.
-idled the car and kept turning the wheel as fast as i could to see if it would do it again
the car has not done this again. its like it never happened. anybody got insight on this?
93 RX-7 FD R1
R1_Stormrider is offline   Reply With Quote
Old 09-28-2010, 08:56 PM   #2
turboed13b
turboed13b is on a distinguished road
What probably happened was you somehow moved the key back causing the engine to die and lock the steering wheel and in your panic you thought it was forward?
turboed13b is offline   Reply With Quote
Old 09-28-2010, 09:03 PM   #3
Project10AE
Project10AE is on a distinguished road
I'm thinking the problem will be very close to the ignition and that maybe the key cylinder is somehow faulty and tripped the key into tripping the wheel lock and cutting of the car. Start the car and wiggle the key without a lot of pressure and see if it jumps out of "run" and cuts off.
Project10AE is offline   Reply With Quote
Old 09-29-2010, 12:03 AM   #4
Garfinkles Motor Works
Remove the covers from the stearing column and see if the switch screws are tight and if every thing is in order .If every thing look correct remove the switch,drill the screws and remove the pin that locks the column, hacksaw .You may have a ghost and do not need it to return .
Old 09-29-2010, 01:18 AM   #5
Ratjar
Ratjar is on a distinguished road
the thing is SO simple to take apart once you hacksaw and make a notch for the screwdriver. gl. sounds scary.
Ratjar is offline   Reply With Quote
Old 09-29-2010, 04:31 PM   #6
R1_Stormrider
i see where you're coming from, and your assumptions are quite viable. i didnt panic when this occurred, but i did get freaked out nonetheless. this event took place at night. i was lettin off the gas after a boost pull and then, CLICK! the whole car died. the headlights went out, the gauge heads up display, the stereo, total power outage. it all just blacked out. so, immediately after i decided to make the car coast in a straight line. the wheel didnt even move a hair of an inch before locking. "ohhhhh shit" ran through my head.
@project 10AE, makes sense. i may have to check the cylinder to see whats up. first the car lost all electrical power then right after the wheel locked with the key forward.
@garfinkles, you read my mind. im goin to get that locking pin removed and never have to go thru this again. imagine if i was on the expressway and this happened? goddamn scary to even think about.
thanks for the input everyone. i hope nobody else has this situation pop up on them.
93 RX-7 FD R1
Old 09-30-2010, 02:03 AM   #7
You lucked out for sure ,glad for that . If you track the car and do not have solid motormounts check out my engine torque brace.
Old 02-14-2011, 12:55 AM   #8
Sideo
Sideo is on a distinguished road
wow thats scary hope u find problem!
Sideo is offline   Reply With Quote
Old 02-17-2011, 07:31 AM   #9
Signal 2
Viable Fossil
Signal 2's Avatar
Updates? Did you ever find the cause?
Jim
VR R1 FD
Old 02-18-2011, 03:35 PM   #10
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
if you have a ton of keys on your keyring it is highly likely that the rearward forces pulling on the keys turned the ignition lock cylinder just a hair to the locked position.
this is why i dislike having a bunch of keys and have several separate keyrings for the cars and shop.
Old 03-09-2011, 03:49 PM   #11
Supernaut
Supernaut is on a distinguished road
I started doing this to prevent scratches and keep the keys off my knee. It is so much more fun driving the car without having tons of keys dangling around.
-93 Spirit R Replica built @ IRP/S1. S1 tuned
Supernaut is offline   Reply With Quote
