|  07-17-2010, 05:33 PM | #1 |
| Rotary Fanatic Join Date: Jun 2010 Location: Okinawa, Japan
				Rep Power: 16  |
				How does ECU calculate fuel/timing cells?
			Just curious about this one.  I know the ECU will probably use rpm on  the horizontal axis of its timing and fuel maps, but what does it use  for "load"?  I'm guessing it's either airflow (calculated through the  airflow meter, maybe measured in g/rev or similar) or manifold pressure,  detected by the pressure sensor. If it's the latter then it would mean that if your pressure sensor isn't reporting the right voltages, your timing and fuel maps could be way out when you're driving, right?
				__________________ Big in Japan: soldave.ismysite.co.uk |
|  07-18-2010, 05:19 AM | #2 |
| RCC Addict Join Date: Mar 2008 Location: Honolulu, Hawaii USA
				Rep Power: 19  |
			Primary load sensor is the airflow meter. The boost sensor is a secondary load sensor. I can't confirm if yours (Kouki) is the same as the earlier Zenki programming, but... Fuel is only modified under "0". Once into + boost, it only modifies ignition timing. This is for Zenki stock ECU's. -Ted |
|  07-18-2010, 06:09 AM | #3 |
				Rep Power: 16  |
			Thanks for that Ted
