			 water jacket mod?!!
				Rep Power: 0 ![]()  |
				external wastegate line/hose
			what's a good external wastegate line/hose to use??  I am sicken tired replacing my silicone hose, it keeps melting.  If using ss line, what size should i get/use??
			thanks in advance..
	86GXL BSC streetport + TD07@13psi  |
		#2 | |
			 Outside the "box"......
				Rep Power: 18 ![]()  |
 -J
	" Life is full of trials and tribulations, misery is optional." -Mark D. White RIP man, we love you... ![]() We specialize in Rotary, Japanese, European and Exotic performance forced induction cars. We also custom build 3/4 multi-rotor engine setups for the street or track. We are the only authorized Fujita Engineering dealer in the USA. Call for authentic FEED parts. Call for ECU tuning. http://www.facebook.com/pages/Gorilla-Race-Engineering/43530496660  |
				Rep Power: 19 ![]()  |
			If you're burning silicone hoses, you think SS lines is going to be any better?
	Most "SS hose" is just a rubber hose wrapped with a SS sleeve. The rubber isn't more heat resistant than silicone (hose) is? Granted, the SS sleeve does reject some heat, but SS has this bad property of absorbing and keeping heat in. I'd really look into trying to rerouting your hoses to see if you can do better. Next, I would look into hose coverings like those fire sleeves for spark plug wires? http://www.heatshieldproducts.com/red-hot_sleeve.php Look, even they use silicone as a material on their fire sleeves. http://www.pitstopusa.com/SearchResu...ategoryID=2429 Check out their inventory... -Ted  |
			 crash auto?fix auto
			+1
	I had SS lines on my old turbo setup. Greddy typeR gate......I was trying to diagonsea boost problem that was acting like a boost leak. Ended up being a pin hole burnt in the SS line. Fire sleeving or other protective wrap is the best insurance. Or hard line.  |
			 water jacket mod?!!
			So, what's a good (or highly recomended) hose to use for wastegate?
			Btw, thanks for all the input..
				Rep Power: 10 ![]()  |
			-3 SS hardline.  Think brake line
	-The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED-  |
			like, with brake line fittings as well?  Sick!
	Rotaries:They are NOT that complicated!  |
			Yeah, pretty much.
		#9 |
				Rep Power: 20 ![]()  |
			Just stop pussy-footin' around and hard line it already.
			   I'm on a hard line trip.  Hard lining my coolant overflow, my scavenge pump and probably a load of everything else   Yes... I like torture and pain.
	The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group  |
		#10 |
			Nah, you just like stroking hard lines
			![]() The coolant system work that you posted up looks damn sexy.
		#11 |
			It'll look drop dead gorgeous when I put in that order for the re-circ tank
			   I'm thinking I may adjust the design a little bit which will lend itself to a more compact design... though you may not like the idea
