Old 03-31-2008, 07:00 PM   #1
sm0keyii
sm0keyii is on a distinguished road
Question Almost ready for rebuild swap/t-78
Ok, I'll start off by listing what I have, and what I still need to buy for my set up. I'm trying to make this rebuild swap/single conversion as smooth as possible. I will be doing this swap after I return from a upcomming deployment. The single set up will be made to run off of pump gas.
What I have:
-Rebuilt engine with new rotor housings and carbon steel apex seals and ceramic coated exhaust ports with plugs removed. Also has large street port.
-Apex'i PFC w/ commander
-Peakboost VMIC kit with modified Koyo rad and hoses for the set up
-used GReddy T-78 kit just missing oil feed line and some other part that Rotary Performance is helping me get.
-GReddy throttle elbow
-Apex'i AVC-R boost controller
-CJ motorsports fuel kit w/ pressure regulator
-CJ motorsports dual fuel pump holder
-two Bosch 044 pumps
-Exedy twin plate clutch kit and the bearings it didn't come with, and a counter weight
-Greddy type-R bov
-new alluminuml AST
-Apex'i turbo timer and harness
-RE Amemiya wheels 17x8.5F+42, 17x9.5R+42
What I still need to buy:
-Fuel pump relay (found out I needed it after a bit of research)
-new 550cc and 1600cc both topfeed
-emissions block off plates
-the stuff I listed above with GReddy turbo kit
-air pump removal pulley set
-custom piping from turbo to throttle elbow
-maintenance stuff; oil, plugs, wires, new water pump, fuel filter, gaskets, etc
What else is planned:
-Removal of all emissions
-Removal of A/C
I think that just about covers all of it. I know I'm gonna need some kind of differential upgrade in the future, would any reputable LSD suffice. I'm planning for a Cusco 1.5 or something of the like. So until i get the diff upgraded I'm not going to use my nice wide wheels. I'd rather burn rubber than shatter my pumpkin. Any suggestions about what else I may need to consider upgrading or replacing would be appreciated. I hope I provided enough info
The car in it's current state has just a GReddy intake (I'll sell it later), SS Auto Chrome DP (which held up quite well). RP resonated MP, and RE Amemiya exhaust.
sm0keyii is offline   Reply With Quote
Old 03-31-2008, 07:28 PM   #2
RXtacy
RXtacy's Avatar
I might go with 850cc primaries instead of the 550s. If you don't have one already you should look into getting a boost gauge as well. I would also suggest an ignition upgrade, the HKS twinpower would probably the easiest plug and play option. While your engine is out check your motor mounts and wiring harness. If your motor mounts are worn I would recommend replacing them with noltec motor mounts while the engine is out. Do you have the stock radiator still? That could be a weak point in your system and wouldn't be a bad idea to change out to an all aluminum one as well. As far as the block off kit goes Banzai racing has the cheapest one I have found so far.
http://www.banzai-racing.com/
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 03-31-2008, 07:32 PM   #3
sm0keyii
I forgot to list a boost guage lol. I was thinking 850cc, but RP told 550cc would be good for idle control. I already have a new radiator modded for the v-mount. I'll be sure to add the twin power to my list and inspect the mounts and such. Thanks for the help.
Old 03-31-2008, 10:31 PM   #4
Brent
Sua Sponte
Brent's Avatar
You'll be good without an HKS Twin Power and 550 primaries as long as you don't turn the boost up too much.
Old 03-31-2008, 10:43 PM   #5
sm0keyii
How much is too much for 93 octane? 15psi+?
