Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Lucky 7 Racing
Lucky 7 Racing www.lucky7racing.net (CA) Engine rebuilds/swaps, used rx-7 parts, maintenance, upgrades/installs.
Old 02-04-2009, 05:48 PM   #1
emoshun
Jimmy @ Lucky 7 Racing
emoshun's Avatar
emoshun is on a distinguished road
Exclamation OEM Retrofit vs. PNP HID Kit
Hello guys, my name is Jimmy, and I am part of the Lucky 7 Racing team.
I'm posting today to help clear the air about what a OEM retrofit is and why it is superior in every way in comparison to the PNP kits you find on eBay.
Alright, here lately we've had alot of new members show up and ask very basic, already covered info. So i took it upon my self to cover the bases so to speak so that you get a general idea of what all is involved with HID.
Class is in session...shall we start?
Bulbs
Ok, first off, lets start with the bulbs. The common mistake some people here is that all these high kelvin rated bulbs are the shizzle. Well, they couldn't be more wrong. The higher you go in kelvin, the less light and lumens you'll have. Pratically anything over 6k is really a waste if your at all concerned with your safety and brightness of lighting. So what is the best bulb out there then you ask? 4100-4300k. It has the most lumens out of all the HID bulbs produced. Thats why car manifacturers still use them today. Below is a graph showing you the variances of the light spectrum. As you can see, 4100k would be right where the "sweet spot" is on that chart. It produces near to the suns same kelvin thus giving you daylight-like output. Think of it like this, high kelvin bulbs would be like being out in the sun with sunglasses on vs a 4100k being in the sun w/o glasses on.
Also here is another good thing to know taken from the FAQ:
Yellow:
1500 k Candlelight
2700-2900 k Yellow painted fog halogen bulbs
Yellowish white:
3200 k Sunrise/sunset
3200 k Premium H7 non painted halogen bulb
3400 k 1 hour from dusk/dawn
White:
4100 k Philips/Osram OEM HID D2S
5500 k Bright sunny daylight around noon
Blueish white
5500-5600 k Electronic photo flash
6000 k Philips Ultinon HID D2S
6500-7500 k Overcast sky
Blue:
9000-12000 k Blue sky
Purple:
28000 Northern sky
12000-30000 k Ultra Violet light (black light)
Some important terms to know:
Watt- Measure of electrical power (w)
Volt- Measure of electrical charge (v)
Kelvin- Measure of color temperature (K)
Lumen- Measure of light brightness (lu)
Capsule- tecnically correct term for a HID "bulb".
Candela- Measure of light intensity (cd)
Ampere- Measure of electrical current
Cut-off- A distinctive line of light produced by the shield in a headlight that blocks light above a certain height in order to prevent blinding of other motorists.
Beam Pattern- The pattern of light that is projected onto the ground which includes angle of lateral dispersion, width and depth of illumination.
Capsule- Another term for an HID bulb. Some refer to HID bulbs as gas discharge capsules.
Optics- The lighting control assembly structured around the bulb, which effects the dispersion of light and it's characteristics to a great degree.
HID (High Intensity Discharge)= Gas Discharge
Halogen= Incandescence
So now that you know about kelvin and some aspects of the bulbs, you might be wondering why you hear the terms D2R or D2S. Well, to put it very simply to you, D2R is a HID bulb that was designed for HID reflector housings. It has a different base than a D2S and also has a painted portion on the bulb itself. Why is it painted you ask? The paint is there to block certain areas of the bulb that would cause excessive glare in the housing. Does the paint affect bulb performance? Yes. A 4100k D2R has slightly less lumen than a 4100k D2S. Can a D2R be converted to a D2S? Yes. You would have to make a notch in the base of the bulb to match that of a D2S. you would also need to delicatly remove the painted portion of the bulb so that it would be completely visible just like a D2S. So enough about a D2R ehh, lets talk about the D2S for a sec. The D2S was designed soley for a HID projector applications. They are completely clear and give out the most efficiency of the two. Thats pratically all there is in difference between those two bulbs Below are some pics of both.
D2R
D2S
Lets move on shall we...
Ballasts
Ok, it has come to my attention some people think that if you use 2 different ballasts on the same bulbs, that one will look different than the other. Is this true? No. A ballast is a ballast (performance wise) as long as we are talking about 35W ballasts. As long as each ballast has the same exact style of connectors, they both can be used in conjunction with each other.
However, most aftermarket HID kit suppliers usually end up making their own sort of connector thus no longer using the oem style D-type connector. Thus that means some HID kits out there that use these different types of connectors, will no longer be able to connecto to a standard D2R or D2S based bulb. They make these kits like that to be universal with their rebased bulbs. If you ever plan on retroing projectors and using oem products, you aftermakret kit balast WILL NOT work and you will either have to replace the ballasts with oem components or be brave and splice in a new plug and oem connector.
So now you may be asking yourself, "so what all does a ballast do in general"? Well, here is a little bit of info on how flouresent ballast work and their basic simplicity. The same somewhat applies to automotive ballast. Our automotive ballast take in your cars DC power and converts it to AC current.
Originally Posted by how stuff works.com
The simplest sort of ballast, generally referred to as a magnetic ballast, works something like an inductor. A basic inductor consists of a coil of wire in a circuit, which may be wound around a piece of metal. If you've read How Electromagnets Work, you know that when you send electrical current through a wire, it generates a magnetic field. Positioning the wire in concentric loops amplifies this field.
This sort of field affects not only objects around the loop, but also the loop itself. Increasing the current in the loop increases the magnetic field, which applies a voltage opposite the flow of current in the wire. In short, a coiled length of wire in a circuit (an inductor) opposes change in the current flowing through it (see How Inductors Work for details). The transformer elements in a magnetic ballast use this principle to regulate the current in a fluorescent lamp.
A ballast can only slow down changes in current -- it can't stop them. But the alternating current powering a fluorescent light is constantly reversing itself, so the ballast only has to inhibit increasing current in a particular direction for a short amount of time. Check out this site for more information on this process.
Magnetic ballasts modulate electrical current at a relatively low cycle rate, which can cause a noticeable flicker. Magnetic ballasts may also vibrate at a low frequency. This is the source of the audible humming sound people associate with fluorescent lamps.
Modern ballast designs use advanced electronics to more precisely regulate the current flowing through the electrical circuit. Since they use a higher cycle rate, you don't generally notice a flicker or humming noise coming from an electronic ballast. Different lamps require specialized ballasts designed to maintain the specific voltage and current levels needed for varying tube designs.
Ok, so now that you've read that, whats a electromagnet...
An Electromagnet
An electromagnet starts with a battery (or some other source of power) and a wire. What a battery produces is electrons.
If you look at a battery, say at a normal D-cell from a flashlight, you can see that there are two ends, one marked plus (+) and the other marked minus (-). Electrons collect at the negative end of the battery, and, if you let them, they will gladly flow to the positive end. The way you "let them" flow is with a wire. If you attach a wire directly between the positive and negative terminals of a D-cell, three things will happen:
Electrons will flow from the negative side of the battery to the positive side as fast as they can.
The battery will drain fairly quickly (in a matter of several minutes). For that reason, it is generally not a good idea to connect the two terminals of a battery to one another directly. Normally, you connect some kind of load in the middle of the wire so the electrons can do useful work. The load might be a motor, a light bulb, a radio or whatever.
A small magnetic field is generated in the wire. It is this small magnetic field that is the basis of an electromagnet.
emoshun is offline   Reply With Quote
