Old 07-25-2009, 04:47 PM   #1
87TurboII
87TurboII is on a distinguished road
Engine Install Check
This is a stupid question I am sure but I would hate to put it all back together just to find out something is not right.
I pulled the old blown engine and just installed the new engine. I did not pull the transmission so I had to try and align it and slide it onto the transmission.
Is there a way to see if they are all together properly? the engine is up against the transmission so I assume the splines on the clutch and transmission must be aligned but should the rear tires spin if the eccentric shaft is turned whiles its in gear?
Just want to double check with others who have probably done this more times than me.
Thanks
1987 Turbo II
87TurboII is offline   Reply With Quote
