Old 03-31-2009, 06:41 PM   #1
Using S5 non-turbo harness as S5 TII harness
I remember seeing a write-up on what to change/add (possibly on the evil forum) but I can't seem to find it. I've been running a S5/ na harness as a TII harnes with no emissions, but I am about to get a motor that has emissions still intact and I figured I might as well leave it since I have to pass smog. What modifications need to be done to the n/a harness to have it handle a full TII system? (I can de-pin or solder or anything needed).
Someone feel free to make a FAQ on this as it will save people mula.
Old 04-01-2009, 11:34 AM   #2
You can do it!
Old 04-01-2009, 08:57 PM   #3
bueler? bueler?
Old 04-03-2009, 07:24 AM   #4
I've done this a LONG time ago...
Basically it's plug-n-play.
Don't worry about the boost solenoid, since this ends up being either the VDI or some extra (emissions?) solenoid on the NA harness...
No need to repin.
Old 04-03-2009, 07:54 AM   #5
sen2two
KTEC
sen2two's Avatar
i have it on my car. its simple. just plug everything in. no modification to get it running. but mine does not have emissions, so im not to sure there.
what I have:
What I had:
Old 04-03-2009, 11:41 AM   #6
sen2two, that's what I did with my other car, which has no emissions... IIRC Lander's blue car is using a n/a harness with full emissions..
Ted,
Will the colors on the connector match up or will I need a wiring diagram? I guess I can do the research myself... but what I needed to know is if I needed to start looking for a Turbo harness or not since the motor is going in the car on the 11th.
Thanks for the info.
Old 04-03-2009, 04:04 PM   #7
the differences involved should be simple enough that just using an NA harness should get things done. Just a little more of your time.
Old 04-04-2009, 05:00 AM   #8
The colors of the connectors should be the same...
The extra should be the VDI (tan or gray or something like that).
Old 04-05-2009, 01:42 PM   #9
what about the S5 turbo knock sensor? I thought that the turbo models have this, but the N/A does not?
Is there an unused connector on the N/A harness that plugs in to it?
Old 04-05-2009, 09:49 PM   #10
from what I've been told the knock sensor will not compensate fast enough to be of any use and to not worry about hooking it up. My 6-port turbo with n/a harness (no emissions) ran that way fine. (until low oil pressure)
Old 04-06-2009, 03:00 PM   #11
Stock knock sensor can be thrown away.
The stock ECU ignores it after 4kRPM.
You can verify this with the FSM.
Old 04-06-2009, 04:07 PM   #12
Ah, very valuable piece of info to know!
Old 04-06-2009, 04:11 PM   #13
fire85gslse
fire85gslse's Avatar
You can do it!
All night long.........
Old 04-06-2009, 07:52 PM   #14
Flooder
Flooder's Avatar
Flooder is on a distinguished road
So seeing that you can use an S5 na harness as an s5 TII harness, is it possible to run an S4 TII motor on an S5 TII ecu/s5 na harness?
AZRX7.COM
Red 1991 A-package(SOLD)
Red 1990 GXL(SOLD)
White 1989 GTUs(DEAD)
Red 1988 Turbo II(DD)
Black 1988 Turbo II(SOLD)
Rebuilt and street ported motor, Garrett T04E Turbo, 3" Turbo Inlet Duct/AEM Dry Flow Filter, Your Mom's MBC, Blitz FMIC, 890cc and 1000cc injectors, Tomei FPR, Walbro, Rtek 2.1 ECU, Taurus E-Fan, Turbonetics BOV, 3" Motoria/Corksport Turbo Back Exhaust, Emissions Removed, Greddy Boost Gauge, Megan Racing Water Temp Gauge, 5one5 Triple Gauge Pod, AEM Uego, GP Sports Body Kit, Fiber Images CF Hood, S5 Seats, S5 Tails, S5 Alt, Dual Alt Pulley, D2 Coilovers, NRG Quick Release, Shook Motorsports Radiator, HID's, AN/Steel Braided Oil Cooler Lines, SUPER JDM TYTE DRIFT BUTTON
www.DensetsuMotorsports.com www.AZRX7.Com www.FloodersAdventure.com
Flooder is offline   Reply With Quote
Old 04-06-2009, 08:07 PM   #15
fire85gslse
Yes, if your sing just the S4 TII block with all the S5 accessories.
Chad
