Old 03-27-2009, 01:43 AM   #1
91convguy
91convguy's Avatar
91convguy is on a distinguished road
gasket sealer or no gasket sealer?
I am about to install a new water pump and a new water pump housing gasket not sure what to do here long time friend and X-mechanic tells me I'd be defeating the purpose of the gasket buy using gasket sealer,makes a little bit since to me. But the Hanes manual tells you to put a thin coat on gasket just between engine and gasket (just one side of the gasket) and sum between water pump and gasket. Someone else told me to put a thin coat on both sides both gaskets put it together and wait a day then add coolant. I myself think it would be best if it was applied on the gasket side that's going up against the housing on both gaskets an that's it.
91convguy is offline   Reply With Quote
