Old 08-11-2008, 12:32 PM   #1
Re-routing of HVAC piping and relocation of units
I'm wondering if there's any detremental affects if I do this? I'm planning on rerouting the piping to be less conspicious (through the fenders), and maybe hiding a few of the componets as well. Is there any reason that this is a BAD idea? I will still leave the access locations available including the schrader valve and the inspection window.
So...? any thoughts or suggestions or reasons why I shouldn't do this?
Old 08-13-2008, 10:30 PM   #2
umm, can you please be more clear on what you mean? Have you taken the dash off and seen just how BIG the units are? I took off the entire AC system, and that helped, but, for example, the heater core is so huge that the only place it can really go is the stock location behind the dash right in the middle.
I'm really confused with what you are trying to say.
Old 08-14-2008, 05:32 AM   #3
the actual HVAC units i'm planning on leaving in the stock location, I'm talking more along the lines of altering where the pipes enter the cabin to connect to those units. for example I'm thinking of moving and fabbing up my own low pressure line by having the line enter the cabin on the drivers side then shoot across to the hookup. The high pressure line will probably be run through the fenders and hook up within the fender. This is of course just rough ideas.
As for the heat i'm thinking of doing the same.
Old 08-14-2008, 07:33 PM   #4
I'm planning on using one of these:
Bulkhead Connections
To pass both AC and Coolant through
I'll also get new lines fabbed up at a local place, but similiar to these.
I'll also be planning around the same time to be tucking the wires and mounting them more centralized behind the engine to further hide the connections using More Bulkhead Connectors
Just to give you an idea of what's going on.
Old 08-15-2008, 10:13 AM   #5
classicauto
crash auto?fix auto
classicauto's Avatar
I think its a neat idea, but doing it to the A/C system is going to require alot of thinking.
Placement of the dryer, length of lines and how much extra refridgerant will be needed afterwards....
To hide the heater core inlets and outlets would be one thing, but the A/C system.....I dunno. You're still going to have lines coming to and from the compressor so there's no way to eliminate those...minimize perhaps.
Old 08-16-2008, 08:21 AM   #6
i dunno, that is a cool idea, but from tinkering around with shit, I think that the way that Mazda did it is prolly the simplest... Shure, it would look a little better, but I think that there is a ton of OTHER stuff you could do to make the engine bay look better.
some of the prime examples:
using FD coil packs and getting rid of the stockers
using FD upper manifold if you're turbo
removing emissions
using electric fan
replacing stock airbox with an AEM Dry Flo filter
getting an aluminum radiator panel
relocate the battery to the interior
Replace the nuts and bolts with new ones as you work on the car.
Well, it's not everything, but doing some of these things makes the engine bay look amazing!
Old 08-16-2008, 08:58 AM   #7
JL1RX7
The only things about the coils is the fc's are the best. Its an upgrade for the third gen guys.
Old 08-16-2008, 10:39 AM   #8
yeah, to the compressor I know I can't really hide those unless I wanted to go with an electrical unit. I don't really plan on being able to hide those lines but to minimize the lines going to and from the compressor I think would make a world of difference.
The big aluminum line that crosses the engine is what I really want to eliminate. After that I can align the different inlets/outlets onto a single bulkhead connection and place them over on the drivers side or even directly over the transmission. Either way it's not that big of a deal.
FC Coils are fine until you go stand alone and want fully controllable spark which would be accomplished using LS1 coils.
Don't have a turbo. I'm NA converting to a 6-port turbo.
removing emissions
Already in the pipeline.
using electric fan
Already Installed
Converting to a Turbo so the stock box will be leaving soon anyways.
Already planning on it and will be getting an aluminum radiator too.
Already done.
Already converting all the nuts and bolts as I go to Stainless Steel Cap Screws or Standard Stainless steel bolts.
Granted I wouldn't even bother with the HVAC system until after I've done those, but as you can see I've already started or completed a majority of those things on that list.
Old 08-17-2008, 07:56 PM   #9
/\ oh, well that is cool then!
Bust seriously, doesntyour bay look a ton better already? The one thing I always hated about the RX-7's is that the stock bay is just so cluttered with CRAP! And it get's progressively worse with every generation, going from the 12A first gen, to the FC, FD with it's 500 miles of vaccum lines, to th RX-8 with all it's emissions bullshit.
I think that making the engine bay look clean and tidy is my fav part of modding my car!
PS: care to post a pic of your bay just for kicks here?
Old 08-18-2008, 06:43 AM   #10
Yeah, I'll post up. It's not a whole lot to look at quite yet, but I'm still working on it a little bit at a time. I just did a tune up. New Belts, new Hose (on the throttle body), Oil Change, new exhaust gasket (Stupid ticket, now I have to call in to see if I can get compliance with the law off of a parts receipt)--I really hope that I can otherwise I'm going to have to wait and go to court.
Old 08-18-2008, 03:33 PM   #11
Here are some pictures. There's still alot of work to go on it...
Someone was asking about the bumper support bar--here's a picture of it. It's the bent bar down by the oil cooler.
Old 08-25-2008, 10:36 PM   #12
oh, THAT bar? No wonder I had no idea wtf you were talking about!
Dont quote me, but I'm 99% shure that is not what it's called... 99%....
Old 08-26-2008, 11:27 AM   #13
That's the only thing I've ever heard it called.
What you were referencing before was the Bumper Reinforcement "Bar".
Old 08-26-2008, 01:43 PM   #14
classicauto
crash auto?fix auto
Just for quick reference:
Round bar near oil cooler = tubular cross member
Bumper support = bumper re-bar (or reinforcment bar)
Old 08-26-2008, 09:32 PM   #15
Thanks for clearing that up, classic! I knew it was called something different, just couldnt remember what, lol!
