Old 03-12-2015, 10:58 AM   #1
Sh00bs
I5's Doritos & dualsports
Sh00bs's Avatar
Sh00bs is on a distinguished road
Retrofit and rx8 engine in...
My friend loves his 8, but hates the rotary engine.
Buying an rb25 to put in it... Yeah ikr
My question is, how hard would it be to put a msp engine in a fb rx7?
I'm a certified welder so fabricating engine mounts and making it fit wouldn't be an issue
Just concerned with the engine working properly
He said engine (complete) trans ecu for $450... It works fine, he just doesn't like it
Sh00bs is offline   Reply With Quote
Old 03-12-2015, 11:03 AM   #2
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
I'd talk with Brian (TitaniumTT) for specific difficulties involved in the swap. He's got some first hand experience sticking more modern engines into the FB.
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-12-2015, 04:46 PM   #3
reddozen
Gold Wheels FTW
reddozen's Avatar
If you want to keep the stock ECU etc:
I would say full dash harness, engine harness, immobilizer, key, and all related OBD2 Stuff. The immobilizer, ecu and key have to be from the same car. I think racing beat can remove the immobilizer (04 models) from the ECU with their flash, but then you'll be limited to something like an adaptronics piggy back ECU to tune. You wouldn't be able to reflash it, but you wouldn't need the immobilizer or a specific key.
With a standalone you'd just need to wire up the basics. This would probably be the easiest / cheapest option.
My Cars:
1974 RX4 Coupe
1991 FC3S RX7 - Sold
Old 05-10-2015, 03:01 PM   #4
Nutsid
Temporarily insane.
Nutsid's Avatar
Difficult. Extremely. The actually engine itself can work with a modified FC front subframe, but getting all the electronics to work properly in order to run the engine optimally (ie - the same as it does in the Rx8) you'd need to run the stock ECU with a piggyback (Adaptronic, COBB Accessport, or use the MazdaEdit program). Even with those things holding true, there are over 90 wires that have to be ran for the stock ECU to operate.
That is just the engine. Then you need to worry about brakes for the increased speed, suspension, and chassis upgrades for the increased power. Tires, blah blah blah.
For the sake of simplicity, there are far better options for a swap. Like any turbo rotary. Get an S4 TII engine. A much more simplistic swap with a much higher potential.
Having said that, and I've been noted as saying it since the Rx8 was announced - A Renesis swapped FB is a fantasy of mine for a daily driver/street driven car. I love how smooth that engine is and the power delivery of it. Those things combined with the light chassis of an FB and I'd be happy.
Kindle
Nook
