Old 11-04-2013, 10:10 PM   #1
Nick SA
Nick SA is on a distinguished road
Parting out two stock 13B-REW engines
Hi Club,
I just acquired two complete 13B-REW engines. My intention is to keep the rotors and housings but absolutely everything else is up for grabs. One is a USDM engine and the other is a JDM engine.
If you need any random parts for your build then please send me your request and offer via pm. No reasonable offer will be refused!
Here is an itemized list of what I am parting out from both engines:
Primary and secondary rails with injectors: $100 for the set
UIM / LIM / Throttlebody: 75$ each or 175$ for all three
Flywheels: $40 each
Stock ECU: $60
Old engine harnesses, no cuts but old and dried out. Good if you want to cut it up and make something custom: 40$ each
Rats Nest: 20$ each
Stock twin turbos (minor lateral shaft play but working great when removed): $200
Exhaust manifolds: No cracks $50 each
FD Igniters: $25
Power Steering Pump: $75
AC Compressor: $75
Accessory bracket: $20 each
Set of FD coils with coil bracket: 50$
All other small parts, solenoids, etc. Will let these go for cheap.
I also have a mint (I really mean it.. 30k miles on these parts, not kidding) 12A rotating assembly: Rotors, shaft, front stack, gears all for $400
I have a recently rebuilt GSL third member with 3.90 gear. All bearings replaced and clutches measured to ensure they are within spec: $250
Please keep in mind that these parts will ship out from Quebec Canada. If you are interested in anything in particular send me a pm and I will send you pics of that part. Thanks!
Nick SA is offline   Reply With Quote
