Rep Power: 22 ![]() |
Please look through this thread before posting in the 2nd Generation Technical section.
This thread was created to answer many of the commonly asked questions that pop up on a regular basis in the 2nd Generation RX-7 Technical/Specific section. It contains a questions and answers collected by all the moderators and many regular members of the 2nd Generation RX-7 specific section. In this thread there are multiple posts on different subjects, covering subjects such as Engines (including engine swaps, modifications, Turbos, and the quest for more power), Lubricants and Cooling, Electrical, Emissions, Manuals and Links, Specifications, Body (including style updates and modifications), Suspension and driveline, and general questions including subjects like what to look for when buying and how long the cars last. The following abbreviations are often used here and in the 2nd Generation Specific section: AAS = Auto Adjusting suspension ACV = Air Control Valve AFM = Air Flow Meter (also see MAF) A-spec = North American Spec ATF = Automatic transmission fluid Auto = Automatic transmission AWS = Accelerated Warm-Up System BAC = Bypass Air Control CAS = Crank Angle Sensor CPU = Central Processing Unit (the Body computer) DEI = Dynamic Effect Intake (found on 84 and later 13B engines) DMM = Digital Multi-Meter (required for most electrical testing on cars) DTSS = Dynamic tracking suspension system (found on all 2nd gen RX-7s) ECU = Emissions Control Unit (also called Engine Control unit) EFI = Electronic Fuel Injection EGI = Electronic Gasoline Injection EMS = Engine Management System (aftermarket engine computer) FB = 1st gen RX-7 81-85 production FC = 2nd gen RX-7 86-92 production FC3C = 2nd gen RX-7 convertible FC3S = 2nd gen RX-7 Coupe FCD = Fuel Cut defender (aftermarket- used only on Turbos with modifed exhaust and stock ECU) FD = 3rd gen RX-7 FE = RX-8 (sometimes also called SE3P) FI = Fuel Injection FMIC = Front Mount Intercooler GS = Sporty Model (in CAN) GT = Sporty Model with Turbo GT Limited = fully loaded every option turbo model. GTU = Sporty model in 88, base model in 89-90 (in USA) GTUs = Sporty model in 89-90 (in USA) GX = Luxury Coupe model (in CAN) GXL = Top line Luxury non turbo model J-Spec = Japanese/NZ/AUS spec model LIM = Lower Intake Manifold LSD = Limited Slip Differential (sometimes incorrectly called Posi or Positraction which is GM's in-house brand name for their Limited Slip Differential) MAF = Mass Air Flow sensor MOP = Metering Oil Pump. Oil Metering Pump as called in the service manual. (also see OMP) NA = 1st gen Miata NA = Normally aspirated/ Non turbo N/A = Normally aspirated/ Non turbo NB = 2nd gen Miata NC = 3rd gen Miata OE = Original Equipment OEM = Original Equipment Manufacture OMP = Oil Metering pump PD = Pulsation Dampener PS = Power steering PW = Power windows SA = 1st gen RX-7 79-80 production Savanna = The name the 1st and 2nd gen RX-7 was sold under in Japan. SE = Base model in the USA in 87.5-88 Series 1 / S1 = 1979-1980 RX-7 models Series 2 / S2 = 1981-1983 RX-7 models Series 3 / S3 = 1984-1985 RX-7 models Series 4 / S4 = 1986-1988 RX-7 models Series 5 / S5 = 1989-1992 RX-7 models Series 6 / S6 = 1992-1995 RX-7 models Sport = 86-87 Sporty model (in USA also see GS) TB = Throttle Body TBM = Throttle body modification TID = Turbo Intake Duct TMIC = Top Mount InterCooler (factory style) TPS = Throttle position sensor TII = Turbo model (does not mean twin turbo) T2 = Turbo model (does not mean twin turbo) UIM = Upper Intake Manifold VDI = Variable Dynamic Intake WOT = Wide Open Throttle 6PI = 6 Port Induction the auxiliary ports, or the not so correct term - 5th/6th ports 13B = Normally aspirated/ Non turbo, 2 rotor, rotary engine. 13BT = Turbo charged, 2 rotor, rotary engine 13B-RE = J-spec Cosmo twin turbo, 2 rotor, rotary engine. 13B-REW = FD twin turbo, 2 rotor, rotary engine. 20B = J-spec Cosmo three rotor, rotary engine. Can I use a 89-91 (S5) tail light on my 86-88 (S4)? Yes with minor modifications to the body of the 86-88. Here is a link on converting: http://www.aaroncake.net/RX-7/taillights.htm Will 89-91 (S5) mouldings or bumpers fit on my 86-88 (S4) RX-7? other than some minor mounting hole differences on the front bumpers, the mouldings and bumpers will fit fine. What size are my wheels? The stock sizes all have an offset of 40mm or 40 ET and are: 14x5.5 (steel) w/114.3x4 bolt pattern (Base) 14x5.5 w/ 114.3x4 bolt pattern (Base, Luxury, 87.5-88 SE) 15x6 w/ 114.3x5 bolt pattern (GXL, Sport, GTU, 91 coupe) 15x6.5 w/ 114.3x5 bolt pattern (convertible) 16x7 w/ 114.3x5 bolt pattern (Turbo, GTUs, Infini IV) In addition please see below in this thread for stock wheel type and weight. On the same vein, the stock tire sizes are: 14x5.5 = 185/70HR14 15x6 & 15x6.5 = 205/60VR15 16x7 = 205/55VR16 Will 3rd Gen RX-7 (FD) wheels fit on my 2nd Gen RX-7? If you have 5 lug hubs and use spacers. Typically you need spacers around 25mm (1"), depending on tires I want to change my wheels to something bigger. What offset should I use??? http://www.1010tires.com/WheelOffsetCalculator.asp Paint Codes: 86-88: Artic Silver Metallic - J5 Tornado Silver Metallic - K8 Brilliant Black - PZ Sunrise Red - RH Crystal White - UC Dover White - WU Noble White - WY Satin Gold Metallic - 1A Claret Metallic - 2H Royal Maroon Metallic - 3A Sapphire Blue Metallic - 5A True Red - NP 89-92: Brilliant Black - PZ Blaze Red - SQ Crystal White - UC Winning Silver Metallic - 1F Shadow Silver Metallic - 3G Harbor Blue Metallic - 5D Brave Blue MC - 5N
1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5 Last edited by Phoenix7; 07-21-2009 at 08:33 PM. |
