Old 03-28-2012, 01:31 PM   #1
magpiemini
magpiemini's Avatar
magpiemini is on a distinguished road
Question Crap Can Racing - New Member
I hope I don't offend anyone but I have just acquired a 1984 RX7 GSL-SE for $200 and intend on racing it in the 24 Hours of LeMons and ChumpCar series.
Hello, just want to find out a few things. I have heard that this model has some weird rear linkage in the rear suspension that I should get rid of if I want to race it. I have no idea what this could be. This is my first rotary car.
We have been racing a 1978 Triumph Spitfire and the first race for the RX7 will not be until December 2012. We have plenty of time to autocross it and take it to track days, install the roll cage and prep the car.
If you are unfamiliar with this form of racing, check it out. You take a crappy car, add the safety equipment and go endurance racing, trying to keep the crap can running.
Any advice on this model will be welcome, I will be searching the forum for advice too.
http://www.24hoursoflemons.com/
magpiemini is offline   Reply With Quote
Old 03-28-2012, 03:20 PM   #2
magpiemini
magpiemini's Avatar
I think the linkage I am referring to above is the Watts Linkage
Old 03-28-2012, 03:22 PM   #3
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
The weak parts of the FB rear suspension are the Watts link and the upper control arms. The Watts link is supposed to keep the rear axle centered, but because of space and manufacturing constraints, Mazda located it in a far from ideal place. The upper control arms aren't parallel and will bind with a side load. Fox body Mustangs have this same problem as do some others. Most of the guys into hardcore cornering usually put in a panhard bar and a parallel 4 link setup in the rear. Then again, if it's a low budget series, you can run it as is, if cornering speeds aren't going to be very high. A lot of people run the stock suspension without too many problems.
Old 03-28-2012, 03:47 PM   #4
magpiemini
magpiemini's Avatar
Any suggestions on where to get the panhard bar and a parallel 4 link setup?
The RX7 would be a class A car, fastest class. Some of them corner pretty hard, especially those out front. We race on tracks like Sears Point, Buttonwillow, Thunderhill and Chuckwalla out West and the cornering gets pretty fast and hard even on our Class C Spitfire.
Old 03-28-2012, 03:57 PM   #5
GySgtFrank
GySgtFrank's Avatar
I got my panhard bar from G Force Engineering. He's closing up shop so I don't know how much stock he has left. Another place that has a lot of rear suspension stuff is Granny's Speed Shop. I'm sure there are more out there somewhere.
