Ask Me About My WANKEL!!!
Difference between s4 and s5 turbo manifolds?
im considering buying a ported stock turbo mani for use on my 12a [fb rx7 ] to do a s5 turbo setup.. how can i tell if the manifold im gonna be looking at is for a s4 or s5 and do the turbos mount up diffenrent or the same and which manifold is better of are they the same
(Tried searching didnt come up with anything useful)
1984 Rx7 Gs - stripped interior re speed coil overs, tokico blues, re speed crossmemeber and mustang rack, diamond star racing wheels 1988 Rx7 Se - Sold 1988 Rx7 GXL - Sold
There's a great write up describing the differences between S4 & S5 turbo engines, turbos & manifold designs (among other things) here:
http://fc3spro.com/TECH/FAQ/ZVK/zvk.html This should answer your question |
destroy, rebuild, repeat
you cannot mount an S4 turbo on a S5 manifold and nor vice versa.
the S5 manifold is completely divided (two equally sized holes, one for each rotor) and spools very fast. The S4 just has one big hole with a twinscroll flapper. Even with working twinscroll, the S4 does not spool as fast as the S5 manifold. however the S4 manifold ha slightly more potential for peak power from the factory S5 manifold has a better wastegate design, but the wastegate door can hardly open before hitting the backplate. grinding material off the door and backplate or using a custom spacer fixes this problem. combined port area on the S5 is about 30mm. however the S4 wastegate (only 14mm from the factory) can be ported to flow better than S5
1993 RX-7 Touring MB, stockport 13B-REW, 9.4CR rotors, T04S 60-1/p-trim single turbo 1986 RX-7 Base project track beast |
