Old 03-02-2011, 11:49 AM   #1
cewrx7r1
The Judge
Pettit FD Toe Links Install
We know that some Mazda production parts are not made to strict tolerances.
But they all will fit without any or much problems. Thus any aftermarket parts should take this into consideration.
Having installed the Pettit toe links yesterday, I had these observations and problems.
(1) Pettit uses machined aluminum bushing adapters that fit into both sides of the spherical bearings. All four have the same length. These are needed due to their bearings being narrower that stock. The stock inner bearing is larger the the outter one.
(2) The inner brackets have more space and require washers to take it out.
Pettit gives you 4 of them.
(3) My left inner bracket required the use of a third and thicker washer. The right inner could have used a third thin washer, but worked with their two.
(4) The left outer bracket was a perfect fit, but the right was too tight. I had to hand sand down both Pettit adapters to get them to fit.
(5) I assume Pettit did it this way to save costs. If so, they should have made the adapters shorter and supplied more washers.
