Old 03-05-2011, 08:09 PM   #1
To_Slow
3mm Wire EDM cut rotors.
Here is some pics/video of some rotors that i wire EDM cut for a custo.
Uploaded with ImageShack.us
Video...
http://www.youtube.com/watch?v=fP0xpjf2ziw
Electrical Discharge Machining (commonly known as "EDM Machining") makes it possible to work with metals for which traditional machining techniques are ineffective. EDM machining equipment makes it is possible to cut small odd-shaped angles in hardened steel. The EDM machining process was developed by the aerospace and electronics industries to provide tolerances accurate to one ten thousandths of an inch. The accuracy of EDM makes it ideal for machining the 3mm opening to accommodate thicker apex seals. The resulting surface finish is ideal for use with any apex seal material and recommended for use carbon or ceramic apex seals.
My link
