Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Rotaryshack
Rotaryshack www.rotaryshack.com (CA) Specializing in carbs, custom turbo kits, 1gen rx7 parts
Old 10-20-2008, 11:50 PM   #1
firzen
High output alternators
Hi,
I remember that you had a thread over at the 'other' forum about high output alternators for sale and you also take in cores for rebuild & modification. Are you guys still doing this?
Thanks.
quote
F/S original mazda alternators modded for high amp output--polished too
i get these custom built custom, and yes they come with a 1 year no hassel warranty
they are direct bolt on units for 78 on up to 95 rotary engines
the FC/FD alternators are dis-assembled, the housing sent out for polishing.. the internals of the alternator get re-worked, the stator is modified, custom voltage regulator installed, new bearings and a couple of other things the builder wont share with me.. once its re-assembled the alternator sits at a solid 14.5 volts all the way up to 180 amp draw!! using the stock pulley
these alternators work great if you run lots of electronics,(IE,big fuel pumps, msd units aftermarket EMS, aftermarket stereo systems, electric e fans,etc, etc..)
