Old 04-06-2008, 05:31 PM   #1
MidnightOwl
BAND. You got talent.
MidnightOwl's Avatar
MidnightOwl is on a distinguished road
Crankcase ventilation?
Okay, I have an 87 TII engine in my vert. I have the emissions removed, so the charcoal canister is gone. I've been doing a little research into crankcase ventilation, and needed a little bit of clarification.
I read that improper ventilation could lead to oil problems, such as blow-by in the turbo, and other phenomena. On my engine, on the intermediate iron, there is a nipple below the oil filler neck, which is capped. The nipple on the oil filler neck is open.
From what I understand, the nipples are used for crankcase ventilation. Air is sucked in from the lower nipple, through the engine, and the upper nipple is used to vent the gases/whatever. Now, from what I understand, the oil catch can is what you use to collect the vapors and oil residue if you have removed the stock systems.
The set ups that I have seen have a breather on the lower nipple, and the catch can attached to the upper nipple. I've also seen a breather on the lower nipple, and the upper nipple attached to a PCV valve which is connected to the intake manifold. I've also seen the lower and upper nipples connected to a vented catch can!
My question is, what can I do? From what I've gathered, I should be able to just attach a breather to the lower nipple to allow airflow in, then attach some sort of canister to the upper nipple to collect the misc stuff coming out.
88 Turbo Vert - mostly stock, S5 turbo, full exhaust, Greddy Profec B Spec II, full emissions removal
90 240sux - daily driver of DOOM.
www.daviddrinkard.com
MidnightOwl is offline   Reply With Quote
