View Single Post
Old 05-31-2009, 05:12 PM   #4
Depends in how many outputs you need. I believe the inputs are the same through out the series, the difference is in the outputs. Make a list of how many you need,
Lambda
fan
fuel/ignition
tackh driver
boost control
BAC
Aux inj
one or two more maybe,
and then start filling in the blanks on the schematic. If you run out of outputs on a 400, start with a 6 If you run out on a 600, then it's time for an 800
