Old 05-17-2011, 10:25 PM   #1141
Lastly is the AST. I really didn't have to do much to this except add a 2nd 1/4" npt bung for the outlet from the rad. That and scrape off all the old powdercoating so i could recoat it..... OH... and I FINALLY after looking for like a year, found a rad cap that matches all of the other caps that I have under the hood. I was so happy I literally jumped up and down and did the bus-driver after I bought it.
The AST is pretty simple and very effective at purging air from a cooling system. Basically you plumb in the two highest points in the cooling system, the highes on the engine, and the highes on the rad, this if course being a rad without a cap, into the AST. The AST has the pressure cap on it.
All of the air in the cooling system collects in the AST. The bottom of the AST is plumbed on the vacuum side of the flow, lower rad hose going into the engine. in my case I have a T-fitting on the frame rail that is also the return from the heater core. From the T it goes into the -10 bung on the lower portion of the "stock" WP housing. So, air and coolant go in, coolant comes out the bottom. Air stays in the AST. The AST is also the filling location
When the cooling system heats up, coolant expands. The air is purged from the AST through the pressure cap, and into the overflow tank. Plumbing from the pressure cap MUST be into the bottom of the overflow tank otherwise the system will just continue to suck air in when it cools. This is what was happening to me the entire trip, but I knew about it and it actually was never a problem
So, on my AST, the top fitting on the side comes from the top of the WP housing. THe highest point in the cooling system on the engine. The bottom fitting comes from the rad, the highest point on the rad. The one in-line with the cap is plumbed into the overflow. Isn;t that a damn good looking cap??
That's right bitches.... them 2 fittings be PERFECTLY aligned... yes, I spent the time to fit the fittings and double check before I welded them up for certain..... hey... suck it... I am that guy and you all know it accepted em for it Isn't that a damn good looking cap though?
When I get some batteries tomorrow I'll add a pic of the fitting from the radiator to this post.... until then... I hope Hades is happy
Old 05-17-2011, 10:33 PM   #1142
You can save different maps now, but on the dongle. As far as I know, the ecu still doesn't store them. Not a big deal though really... I can save all the config files to the laptop.
You still have to buy extra shit to make it work..... that's pretty lame
Make sure that RTek is for a turbo engine, not NA
I think if I showed TTT my engine bay he would rage and make me his little midget bitch... Though I think I'm bigger than him.
I might... I just might... but you have good reason... it's in development.... when it's all done though I'm going to come down there, tear it all out and say - NOW DO IT AGAIN!!!!! with paint and powdercoat and ceramic coat and well.... you already got that Raychem so at least that's one thing that you don't have to do over I wanna see it damnit
Old 05-18-2011, 03:30 AM   #1143
Mazdabater
FC3S
Shoulda tig welded it lol.
Old 05-18-2011, 01:34 PM   #1144
mazpower
Rawr Bearclaw
mazpower's Avatar
mazpower will become famous soon enough
yeah yeah my dumbass didn't fully tighen a cap after checking the coolant and it got lost somewhere in Virgina doing a burn-out infront of some car with the license plate FRSH-SXY I NEED to find a pic of this car... it was epic...
Ask and ye shall receive...
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
mazpower is offline   Reply With Quote
Old 05-18-2011, 02:50 PM   #1145
MaczPayne
Bah!
MaczPayne's Avatar
Always improving, wonderful! Definitely giving me ideas about my future setup
Johnson
TA FC in the works!
Old 05-18-2011, 06:20 PM   #1146
hades
what is the gray "tank"? that would be under the UIM?
I hear you about the AST. Cummins is a whore about radiator fill and de-aeration testing.
More pictures.
This is going to tear
Old 05-18-2011, 07:02 PM   #1147
Vacuum and pressure tanks for the sequential twins. Not only did I not have a place to mount them cleanly, but if you look at and read through all of the sequential diagnosis (at least the ones I was seen years ago when I first started this ever lasting nightmare) no one ever mentioned testing of the tanks. One of the tanks I bought for volumne measurement WAS leaking. Makes me wonder how many people poorly running sequentials were dropped becuase of a bad tank. Anywho, I thought this was cleaner, more elegant, and probably got rid of some headaches as well.
It makes sense, that's a whole lotta load and heat. I think one of the reasons people overheat, blow engines, warp shit, whine, is because of airpockets trapped and creating hot spots. Just my thought though
More pictures.
Soon.... SOON...
Old 05-18-2011, 07:33 PM   #1148
hades
good solution for the pressure / vac tanks.
we vacuum fill the trucks at work. Its still a challenge to get a good fill because of all of the variations of trucks we build. Its hard not to get an air pocket trapped until after the dyno. Still I wish I had a vacuum fill at home.
Old 05-18-2011, 07:47 PM   #1149
hades
FYI - since you are banned.
Tom94RX-7 dyno'd his car on stock non-seq. twins (street ported).
411hp max. 386 max torque. @22.9 psi. the different runs is base, 2% less and 2% more boost to hit 411.
just thought it would be interesting compare your numbers once you are tuned. But then again you do have those BNR's now. what were your old numbers?
Old 05-18-2011, 11:39 PM   #1150
Thanks man.... I dunno what a vacuum fill is... but it sounds cool
nice sig btw
Old 05-18-2011, 11:46 PM   #1151
Damn.... that's impressive but that is an ASSTON of boost!! Those turbo's won't last more than a few hundred mile at that boost level.... still though, impressive. He's also running a correction factor of 1.04, so pull the correction factor out and he's @ 395rwhp which is still impressive. I was @ 405 NS and 400 sequential and that was @ about 14-14.5 psi. I've got to get back now that we've got the BNR's on there and holding 17psi. One of the most impressive things about the BNR's was that it shifted the peak torque about 1000rpm. Peak torque was at about 7800... in other words, the thing just hauls ass and continues to accelerate till redline.
Oh, EMAP was reduced across the board as well, meaning that the BNR's are more effiecent that the stockers at any boost level. Need to get back on the dyno and get some real nuimbers then report back.
Old 05-19-2011, 12:33 AM   #1152
Brakes - Part 1 of 3
So tonight, to appease Hades we will be discussing my rear brakes..... These are what I believe one of the keys to significantly shortening stopping distances. I've NEVER been able to lock up the rears in this car regardless of how hard I tried, how many different pads I tried, it didn't matter, the rears just don't want to lock up. Hell, they don't even want to dust all that much! The brakes in the front are massive, and that's really just to deal with the heat, give me as much torque and clamping force as possible, and a WIDE selection of pads.
Here's what came from FastBrakes. We've got a set of custom hats, a pair of wilwood rotors - 12.2x.81", a pair of wilwood Combination P-Brake Calipers... single piston sliding with an ebrake mechanism, a Lokar e-brake cable kit and a set of wilwood BP-10 pads. Believe it or not, the stock... well, the stainless braided lines that I have fit perfectly. They just needed to be slightly re-clocked.
Stock rotor on top, and the new bare rotors underneath..... more bigger = more gooder when it comes to brakes
You can see that the thickness of the disc is about the same. On the bottom is an assembled rotor, on the top is a bare rotor and the stock rotor ontop of it.
Stock caliper in the wheel... as you can see there is plenty of room in there for something more gooder...
Bare rear upright with the adapter bracket installed. I actually pulled those studs out and cut them a little shorter.... just because that's the way I am....
And the installed rear kit in the wheel
As you can see... there isn't much room for anything else....
The Ebrake cable kit was pretty damn easy to install. They had the wilwood caliper in mind when they designed it so mating it to the cali was pretty damn easy. I then ran the cables under and around the uprights, up along the swing arm and to that little sweet spot on the chassis where the stockers meet.... it really is a nice little kit. To attach it to the factory cable, I took the little block that was pre-drilled and tapped to use those little allen key set screws and welded that to the factory cable splitter. Then attached the cables, tightened them down and viola.... a wonderfully functioning e-brake.
Bleeding the calis was a PITA though, I mounted the left on the right and the right on the left to make it easier to run the e-brake cable. If I had mounted them on the proper sides..... the cable would've had to take a few really tight turns and I was afraid that it would wear fast, kink, not work very smoothly.
As you can imagine, bleeding a new caliper when the bleeder screw isn't on the top, can be a little................ time consuming I guess. Mazpower was intown and helping me out and he had a great idea.... cut a block of wood to wedge in the caliper to keep the piston from moving when you pull the cali off to bleed it. Damn good idea. I've since bought a really sweet little brake caliper service KIT that I can use to hold the pistons in place for bleeding.... pretty cool stuff. I keep finding myself tightening down the prop valve getting more and more braking force in the rear. One of these days I'll torture the car around a few local rds and quickly get out with my little lazer thermo-probe and decide if I need to bump up the rear pads. Sadly, there isn't a big selection of rear pads for this caliper. I'm thinking about buying the hotter set of pads and sending the pads I have now out to Carbotech... they claim they will build a pad for any caliper if they have a set of pads.... hmmmmmm... this is interesting for damn sure.
Anywho... that basically covers the rears... I'll try to get a few pics of the ebrake setup over the next day or two... I guess.... maybe..... GRASS!!!
Old 05-19-2011, 12:35 AM   #1153
just a fwe more pics....
Old 05-19-2011, 06:00 AM   #1154
hades
nice sig btw
we pull a vacuum on the system has its filled - in theory there should be no air trapped.
Old 05-19-2011, 08:05 AM   #1155
How well does practice line up with theory?
