Old 05-20-2010, 08:56 PM   #91
Nismo
400WHP or bust
Nismo's Avatar
Originally Posted by Max777 View Post
What I meant was, you take off the brake caliper, and then you hit the rotor in the space that the caliper left open? Should be plenty of room, no?
I don't know man, kind of hard in my 20x13 garage, and the only sledge I have is 12lbs.
Kevin, did you remember to touch yourself while everything was drying?
I touched myself after every step!
Old 05-20-2010, 09:07 PM   #92
You need to be careful there pumkin, especially with dirty hands, if you clean yourself off with acetone make sure you don't get any down your pee-hole.
Old 05-20-2010, 10:04 PM   #93
project86
Can't.Make.Up.My.Mind.
project86's Avatar
That sounds painful....
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 06-09-2010, 01:54 AM   #94
Nismo
400WHP or bust
Nismo's Avatar
Well I got my Shine hood, I am pretty happy with it, but little did I know how thin it is, going to have to dowel and fiberglass the underside to get some strength, Joe brought this to my attention, and I am happy he did!
Old 06-10-2010, 07:21 AM   #95
Which hood did you get from Shine? Mine doesn't seem to have any strength issues...
Old 06-10-2010, 09:33 AM   #96
Nismo
400WHP or bust
Nismo's Avatar
I got the FRP, Joe recommended that I add some material to the underside as it is fairly shin and could cause cracking to the paint. So I will get some 1/4'' dowel, and fiberglass over that.
Old 06-10-2010, 12:47 PM   #97
Ah - did you get the Panspeed version or their "sexy" style?
Old 06-10-2010, 03:49 PM   #98
Nismo
400WHP or bust
Nismo's Avatar
Sorry yeah the panspeed!
Old 07-13-2010, 09:29 PM   #99
Nismo
400WHP or bust
Nismo's Avatar
Little update, been driving the car N/A since May 2-4, and loving every slow minute of it!
Fixing small things right now, like the wiper switch here is how I did it.
Cut an access hole in the back of the switch:
Desolder these 6 pins:
And these 6 pins:
These are the replacement replays for the ones I removed, $27 bucks for them both shipped over night from MN:
New relays in place:
Video of it not working before, you can hear nothing but the single speed works:
Here you can hear it working on all speeds:
Old 07-15-2010, 07:34 PM   #100
Nismo
400WHP or bust
Nismo's Avatar
Well the Exhaust has been ported, the intake has been polished!
Didn't change the intake timing at all, just opened up the exhaust a touch, I am hoping this will make the turbo spool like the stock one once did.
Here's a few pics:
I'll spend a little more time cleaning them up, but it's going to get dirty again as soon as I fire it up, so it's not going to be a like a mirror.
Old 07-15-2010, 09:01 PM   #101
I've had good success opening the exhaust a little sooner. I generally don't touch the exhaust closing or intake opening on turbo engines. Has worked well for me in the past.
Are you going to portmatch all the main's/block Kevin?
Looks good so far...... from what I can see anyway...... do you own a camera
Old 07-15-2010, 09:38 PM   #102
Nismo
400WHP or bust
Nismo's Avatar
I I just ported to the bottom of the stock chamfer, and added a new one! I guess I could post better pics, but that requires work, I'll get some later if you are good I'm no porting god, and I never will be.
I have port matched all the manifold yes.
Old 07-15-2010, 11:48 PM   #103
MaczPayne
Bah!
MaczPayne's Avatar
Where did you buy the relays for the wiper switches?
Johnson
TA FC in the works!
Old 07-16-2010, 12:36 AM   #104
Nismo
400WHP or bust
Nismo's Avatar
www.digi-key.com
part number:
G6C-2114P-US-DC12
Old 07-16-2010, 07:27 AM   #105
classicauto
crash auto?fix auto
classicauto's Avatar
neither was dave gibson, and yours look much better
I like the stock overlap port job. Someone else in ontario decdied to do that with a single turbo'd rhotormhotor......
So can we drink beer and point at your engine pieces at BCM or what??
