Old 02-10-2010, 02:31 AM   #91
helghast7
F yo couch!
helghast7's Avatar
Originally Posted by frank View Post
Show us Your BEST Quote from Any reputable Body shop or Airbrush Artist, & We’ll BEAT IT, Guaranteed ! - www.LionzDenAuto.com
you better be careful throwing statements like that around, theres alot of people on here, like me, that will call you out on that end end up getting a whole car painted for 100 bucks from you
87' n/a FC
92' ZZR-600 sold
07' CBR600RR
more to come
Old 02-10-2010, 08:33 AM   #92
When it comes to craftsmanship, you get what you pay for. I'm not cheap, you are..... where do we go from here?
Abdul needs some body work before Deals right?
Old 02-10-2010, 12:43 PM   #93
FC3S Murray
frustrated!
FC3S Murray's Avatar
Holy shit Brian you have been busy!!!
You make me nervous...I have always used the pinch welds for jacking points....I am a bad man. I went and looked at my undercarriage and they are clean as a wistle(Cali car and never driven in bad weather, there or here in Montana. Regardless I have moved my jack stands to where they belong.
How difficult is the installation of that Traction Control system? Just curious to how you would set-up that monitoring system.
Same pig, new soul
Old 02-10-2010, 02:40 PM   #94
I'm going with the MoTeC traction control Multiplexer, the TCMux. With the M"hundred series" you can wire the signals directly to the ECU IFF they are hall effect signals. If they're a mag signal like the stock ABS system is, they need to be converted to a Hall Effect signal. MoTeC has the converters, one per axle. In my case though, I have 4 digital inputs, right now one is wheel speed off the driveshaft, one is low sump, and the other low 2-stroke. Becuase I don't want to give up the low level warnings (I could with a simple LED light, but want them to trigger an RPM limit if they do go off) I needed the TCMux. It takes all the signals and converts them to a coded signal that the ECU sees. From that it gets wheel speed, both driven and rolling, calculates slip, and activates or doesn't activate the traction control.
The Traction Control itself can be setup anyway you want it to. Ignition retard, fuel cut, hard cut, boost dump etc etc. In our case, can't really use ignition retard becuase it'll melt turbo's, fuel cut is a bad idea, hard cut can get dangerous so I'll be using the boost dump. I suspect that the boost dump won't do everthing that I want it to. So I may be changing to a DBW which is definately the way to go. The ECU senses the slip and backs the throttle off for you. Can't get much better than that.
The problem that us rotary guys have is the way the earlier MOP's work, it's a feedback system (which is better than the renni's non-feedback system) and the ECU just doesn't have the outputs to run two basic DBW systems. So if I do go the DBW route, I may need to get MoTeC's DBW-4 which is a CAN commincation setup, or ditch my MOP and run a DBW setup and save whatever the DBW-4 expense is. But this is next winter stuff
I will tell you now though that the FD will be a DBW system, and I won't be running the OMP on that motor, so I'll probably ditch the OMP on the FC as well.
As long as you're using the factory jack on the pinch welds you're good to go. The factory jack doesn't put any weight on the seems, it uses the seems to keep it from slipping off. It's when shops use them for lifts, and home guys use their floor jacks that you run into problems like the disaster that I'm dealing with. I'm actually heading outside shortly to get back at the FC. Undercarriage is completely clean so it's time to flip her over and strip all the harnesses out, then wash the underside..... and the floors after I'm done
64 days....... wow.... need to stay busy
Old 02-10-2010, 11:35 PM   #95
64 days to go and we've hit rock bottom
Got a bunch more done tonight and we've turned the corner. Everything has been stripped and cleaned. I'm hoping that the repairs will be done by the end of the weekend and the herculiner will be on too. I think that's a little ambitious but we'll see.
So the FC is shiny side up again but man is she looking bare. The only things left on the car are the woper motor, the MoTeC and the fuel filter
Old 02-11-2010, 12:46 AM   #96
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Your car looks as good as always Brian, can't wait to see the fabrications you come up with for the FD.
Old 02-11-2010, 08:21 AM   #97
Are you taking the cage out to spray the LS?
Old 02-11-2010, 12:33 PM   #98
Thanks Tyler, as soon as the FC is done we're rolling the FD in for the same treatment as the FC is getting now. I really just want her clean and one color, then I'll start all the fab work and welding, then reprime, undercoating, lizard skin, etc etc. I'd LOVE to have her done in a year..... we'll see.
Definately, gotta take the base plates off for the herculiner and I'm always one to remove a part rather than tape it off. I've found it takes about the same time but by taking it off you remove the chance of overspray and get better coverage..... kind of a no brainer in my eyes.
Old 02-11-2010, 02:06 PM   #99
BigIslandSevens
BigIslandSevens's Avatar
Hey Brian,
Thanks for the offer of pics and measurements on the rotisiree. Whenever you get a chance to do that it would be great. No rush, you have enough on your hands. I think it will be a good height for all three gens. Both the FB and FD bodies appear to be shorter from rockers to roof visually than the FC. I can always modify the original design.
Dave
Old 02-11-2010, 03:40 PM   #100
Does Kirky have a part # on that bolt in cage for the FC or was it simply made to order? I'm still probably going the autopower 6 point mainly so I can add door bars to fulfill the requirement, but I love the connection in the rear and the x brace.... the added trans tunnel bar is a good idea too....
Old 02-11-2010, 11:28 PM   #101
helghast7
F yo couch!
helghast7's Avatar
engines going back in this weekend! wish me luck lol
87' n/a FC
92' ZZR-600 sold
07' CBR600RR
more to come
Old 02-12-2010, 09:24 AM   #102
Originally Posted by BigIslandSevens View Post
Hey Brian,
Dave
No worries Dave, glad to help out. I was actually planning on grabbing them today but I got work from my buddy that we're heading up to ME to pick up his Landi...... WOOT!!!! Another 14 hr road trip and one mkore project!!!! I'm up to 5!
My FC, FD, boat,
Alex's FC
Buddies boat
and now the Landi will be here for a few tweaks before my buddy head off to live outt that thing for a month.... sweet! This is the motivation I needed to start cranking into thoat 36hr work days
Kirk had a few part numbers and options. When I spoke with them they didn't have something perfect for me. I had them build me their bolt in hoop as a weld in piece, then I bought their weld in full cage kit (yeah I know but I was hoping) When I got it I installed the hoop and welded the x-bars up in a weld in style, but made them bolt in, then I added the trans braces myself... had to order some extra material for them. The cage put the front kickers WAY to close to my head, found this out after I tacked it in so I just cut them out. The dash brace actually turned into my front bumper support and the door bars are being used for Alex's front bumper support. Kirk is great, they'll work with you.
Old 02-12-2010, 09:25 AM   #103
Good luck man! Gimme a shout if you've got any questions.
Old 02-12-2010, 09:58 AM   #104
Ah - good to know on the cage. I knew it looked custom but the bolted in factor was throwing me...
Old 02-12-2010, 06:48 PM   #105
helghast7
F yo couch!
helghast7's Avatar
thanks Brian
hopefully things should go smoothly...but im sure your going to end up getting a call anyways lol
87' n/a FC
92' ZZR-600 sold
07' CBR600RR
more to come
