#1 | |
Rep Power: 22 ![]() |
![]() I don't sell junk. I fix it (or attempt to) Damn right. And that was what? 5-6 years ago?
1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5 |
#2 |
Rep Power: 10 ![]() |
Something like that, yeah... I think it was the year of my rd trip... which was 2010
#3 |
Can't.Make.Up.My.Mind.
Rep Power: 18 ![]() |
I've been slackin'. Next plans are to put in the new trans cross member and poly mounts. I'll most likely end up doing that on sunday or monday. After that the fixing the leaky oil pan is on the list and while I'm down there doing poly motor mounts as well. Part of the hold up is being out of money haha. I need to find a job badly.
'90 GTUs Stay up to date with my photography '06 Toyota Highlander Hybrid '10 Toyota Prius "Initial Success or Total Failure" |
#4 |
Also.. Id quickly like to revisit the idea of swapping miata gear set into the FC trans. Does anyone happen to know what kind of power that set up can handle? In doing all the mods to the car for the future i'd like to set things up as i go so that it will all manage the future goals of power.
#5 | |
So, like most RX-7 issues, its usually the driver at fault.
#6 |
IT'S ALIVE!
Rep Power: 17 ![]() |
I'd say about as much as the N/A RX-7 transmission. That is, not too much. I've seen both transmissions completely disassembled and I didn't see anything that would indicate the Miata gear set is any stronger or weaker. That's not to say there aren't any differences. I used a gear set from a '96 Miata and I noticed the following differences versus my stock '89 transmission:
-Second gear has two synchronizers -The reverse gear has a helical cut -Small casting differences in the bearing plate -No gigantic weight on the output shaft I used the front (bell), gear (middle), and rear (tail) housings from the RX-7 transmission. The bearing plate and everything else were from the Miata transmission. |
#7 |
That would be the truth.We maintained a metric fuck ton of ITS cars up at Speed1. Teams would go through 3+ trannies a season and the failures were ridiculous. As in stripping the teeth from the gears. Once we started cryo'ing the trannies they would last all season and just need new syncro's in the off season... and the fluid would drain gold It was fucking hilarious.
#8 | |||
So you think if i had the gears cryo treated id be ok even if i ran around 350whp? I mean I'm not gonna be tracking the car. Just spirited driving really.
#9 | |
Like paint....
#10 | |
As far as paint goes I'm still going back and forth about it. Not sure if I want to leave it Red or do a color change. Either way I'm gonna feel the need to pull the engine for the paint stage. It will really bother me if it doesn't look good under the hood too. And if I'm gonna go that far I might as well change the color.
#11 |
IT'S ALIVE!
If you're not going to track your car the N/A transmission with Miata gears will probably be fine. ITS cars spend a lot of time at high engine speeds so even with less power they're putting more stress on the transmission. You could always look into a transmission cooler if you're still concerned. In my opinion it's still less expensive and confusing than having to deal with a turbo transmission in an otherwise N/A car.
#12 | ||||||
![]() Quote:
#13 | |
Disregard my post above this then. You must have posted this at the same time i posted.
Paint is high on the list after I get the other small things worked out. Im planning to get a quote for it soon. I'd be more than willing to do it myself but i don't have a place to do the work. I don't really want to close my wife out of the garage but i may talk to her about it after i get a quote. I have a feeling the price to paint might motivate her to let me make a mess of the garage and buy a compressor. That being said however, as long as its been since ive painted anything a shop could certainly do it better than me at this point. I guess what i could do is the body work portion of it and then trailer it to the body shop for paint. Although typically they don't like that sort of thing but ill probably ask about it when i go for the quote just to see what they tell me.
#14 | ||
To me a trans is weak when it can't handle the torque and teeth strip and shafts twist or break. When you over extend a shift hub and the detent balls pop out into a tranny spinning at 9k, can you really say the tranny's weak? not in my eyes. In that case you're a fucktard who needs to learn to shift properly. That's what I plan on doing actually... that's what I did for the most part last time... although I rented the booth and shot it myself. Not sure I wanna do that again though.
#15 | ||
![]() Quote:
![]() As far as the shifting properly goes... are the people who can't do it properly just pulling and pushing WAY too hard during the shift? Did you rent the booth from a local body shop? How long did you rent the booth for? What did they charge you?
| Bookmarks |
