Old 01-06-2014, 10:58 PM   #76
chibikougan
chibikougan's Avatar
Cold Weber?
Old 01-06-2014, 11:04 PM   #77
no its making the tach jumpy
Old 01-07-2014, 07:59 AM   #78
2gslse
maybe the pick-up is failing in the dizzy they move a little and the wire may be broken inside.
2006 VW TDI commuter
Old 01-07-2014, 08:22 AM   #79
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
Take the tach signal from the msd if you can and see if it works fine.
Is it just the tach or do you feel it actually missing?
Old 01-07-2014, 11:40 AM   #80
Im going to try the tach off the MSD as well. I yea, I actually feel it missing. Stumbling quite badly when it occurs.
Old 01-07-2014, 11:49 AM   #81
i have some spare dizzys so ill be changing it out too if the problems persist past the coil and ignitor.
Old 01-07-2014, 12:10 PM   #82
Old 01-07-2014, 09:04 PM   #83
dizzy failed mechanically. was making loud clunking noises, replaced and she runs good minus the idle circuit. I need to get that dialed in.
Old 01-07-2014, 09:30 PM   #84
chibikougan
Sweet.
Old 01-21-2014, 01:17 AM   #85
Old 01-21-2014, 01:21 AM   #86
made this to break up the pressure waves
Old 01-25-2014, 10:15 PM   #87
scarsofcarma
scarsofcarma's Avatar
scarsofcarma is on a distinguished road
Whoa... what is that about? I'm very curious
scarsofcarma is offline   Reply With Quote
Old 02-11-2014, 09:16 PM   #88
breaks up and/or deflects the pressure waves (supposedly) and prevents them from bouncing back against the flat top metal lid.
Old 02-11-2014, 09:18 PM   #89
Found some larger 65 pump jets. Seems to have help some. Car still has off idle / light throttle leaning issues causing dead spots.
Racing beat muffler has replace the flowmaster so know it sounds better and quieter. A much needed thing.
The motor that controls the vent mode for the heat went out so i just removed it so i can manually change the settings. I might fix it proper some day. I just was tired of no defroster.
Also powersteering is back in the car with mazdatrix heim bumpsteer bits.
Old 02-16-2014, 03:09 PM   #90
