Old 12-04-2012, 01:16 PM   #1
Looking pretty good man. Lots of hard work in there and I'm sure you'll have a good reliable run for rally..
Old 12-04-2012, 02:01 PM   #2
thats the game plan. the 1.8 would have been better, but with this engine being a little shorter, i didnt have any clearance issues when i lowered the engine down. Not a big deal, ill either High comp it or turbo charge it down the road
The work i've enjoyed though. Except the wiring, have not gone into such extensive and detailed stuff in a very long time. Also on a budget so i cant just buy what i want / need. Been creatinve in taking pigtails and wire from other sources. case in point both relay boxes are from a Ford Aerostar i believe.
Old 12-05-2012, 12:22 AM   #3
Looking good, Alex! Nice work! Too bad you can't bring this to work so you can wrench on it there for the time being lol.
Old 12-05-2012, 09:34 AM   #4
Thanks Eric, wish i could work on it in a warmer climate. The overhang is nice, but doesnt keep out the coldness.
Old 12-17-2012, 11:30 AM   #5
couple progress pics! Fuel lines are getting there, megasquirt is in the car, just need to run the TPS, IAT, and ignition outs. Have to weld a bung to the intake manifold for the IAT though. Coolant stuff is almost finished! Might start here soon!
Old 01-10-2013, 11:43 PM   #6
managed to make my bulkhead today despite the snow / cold! Pictures should explain most of what happened, but it was a road sign, cut to a circle. drilled for the return and feed bulkhead fittings. the two original sign mounting holes will be used to hold the bulkhead down, but i didnt feel like getting the welder out to make the brackets to hold it.
still either one 180 degree fitting for braided line or two 90 degree 3/8 barb to 6AN fittings so i can finish plumbing the system. then ill get the gas tank up and drop the lines to the tank!
Also the fuel pump stuff is done!
Old 01-10-2013, 11:50 PM   #7
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
You're not going to have DOT knocking on your door wanting to know where their sign went are you? This is a kick ass project.
Old 01-11-2013, 10:52 AM   #8
actually i got the sign legally! they sell off old signs for the price of scrap at the county road department (at least here). Or in my case, i just know some people who work they and they just gave it to me.
Old 02-18-2013, 10:26 PM   #9
some updates!
vast majority of wiring is done! headlights, taillights, brakes, etc working. little more detail work left with chassis wiring. Gauge panel is done, ecu wiring is done. Trying to work to get the car started. Thinking i have a setting wrong with the Megasquirt causing spark to be 180 out.
Old 03-17-2013, 12:48 AM   #10
helper springs installed!!
Old 03-17-2013, 08:51 AM   #11
I didn't get a chance to post a reply to your earlier pic when you showed how far off the spring was. I was going ask if you had a source for helper springs, lol.
On a side, we're running a megasquirt v3 on our Miata now. Just fired it up last thursday. Don't know if you got it fired up yet, but if you need some startup configs, just let me know and I'll send you what we're using. I now have about a total of an hour experience with these megasquirts, so I'm by no means an expert, but we can probably help each out getting them running. What software are you using to tune it?
Old 03-17-2013, 12:42 PM   #12
im on MS2 with Tunerstudio. My friend had the super-bitching version of TS so we have been running auto tune. Which is basically awesome. The car was running big right with the 1.8 turbo map i found. But yea, drove it for the first time yesterday. Lots of tuning to do still. Need spacers to keep the wheels from rubbing the spring though.
actually the odd problem im having is that the output from the AEM 30-4100 is reading off on the megasquirt and we couldn't find a away to get it right... It was like a full digit off, so we just compensated in the map for now.
Old 03-17-2013, 02:40 PM   #13
We're looking at the upgraded version of TS as well for the autotune feature considering there is about 4 days total to get this car ready for a track weekend.
I've heard the AEMs can be off like that as well. We're using one currently but will probably swap in an innovative just to see if it fact does read differently...
Old 03-18-2013, 11:07 AM   #14
the guys at DIY gave me some information and I guess under "tools" then calibrate AFR you can give it voltage points to make it custom. Going to give that a whirl today.
Old 03-25-2013, 12:00 AM   #15
