Old 06-29-2009, 11:54 PM   #61
How did this ever turn out for power?
Old 09-20-2009, 10:41 PM   #62
anyone have current updates?
also i would like to have altitude added in. My testing will be at around 4000 ft which will show less than anyone at sea level.
just need a wideband
Old 09-23-2009, 11:46 PM   #63
Only Updates I have are as follows:
216 WHp = 63% Duty cycle on 4 - 460 cc/min injectors on Peak and hold (14.16 V from alternator) giving 13.3:1 AFR. This comes from my Haltech data logging while I was on the dyno making 216 WHp. This is very comparable to online calculators.
I still think that 200 WHp is attainable for you, you have a better intake setup than I do (although mine had been heavily modified from stock). This should offset the altitude difference (I am at 800 ft).
Old 09-24-2009, 06:43 PM   #64
i really need to build an engine for the car. The original 200,000 mile 6 port engine will die sometime.
Old 09-25-2009, 10:49 AM   #65
Tanj!
Tanj!'s Avatar
Tanj! is on a distinguished road
It might last longer than you expect. Mine is up to 245k now and still running strong.
Tanj! is offline   Reply With Quote
Old 09-25-2009, 05:04 PM   #66
knowing my luck that is true, but it wouldnt hurt to get something in the works.
Old 11-01-2009, 06:59 PM   #67
only 19 days til idaho. I am going to take on some changes once i get to working on the car again. Primarily going to CAS and having ignition control. Additionally, i am going to get a wideband so i can properly tune the car. otherwise its just guess work.
Old 11-01-2009, 08:03 PM   #68
What kind of port work did you do?
How are you actuating your 6PI?
That manifold that you used has to flow better than the stock 6-port manifold, maybe you can get 200 WHp. I am really convinced that the biggest problem with 6-port blocks is the late intake port close and the second biggest problem is the intake manifold.
Old 11-02-2009, 01:24 AM   #69
PercentSevenC
Custom User Title
PercentSevenC's Avatar
The third problem is the tiny primary ports. If you use GSL-SE end plates you can use a Y or nitrided R5 intermediate plate, but then you have to use pre-'86 rotor housings.
Old 11-02-2009, 09:23 PM   #70
my current engine is 100 percent original s4 6 port. I need to build something more suitable.
Old 11-03-2009, 12:04 AM   #71
You have an aftermarket intake manifold though, right? That has to help your power, there is not much worse design than the factory s4 intake for power.
Old 11-03-2009, 07:10 PM   #72
yea its aftermarket
Old 11-09-2009, 08:16 PM   #73
Ok, maybe I am missing something, but what makes the P-port expensive?
All you need is a set of housings, some aluminum-ceramic or Devcon and a hole-saw.
Then you can fill your side ports with iron-ceramic or Devcon and you have a P-Port.
I doubt that you would need a 2-piece Eccentric shaft, etc. for a 250 WHp build.
Old 11-09-2009, 10:24 PM   #74
eh, i guess homebrew wouldnt be soo bad to try. hmm now my gears are turning. i wonder what the limit of my ITBs would be.
Old 11-11-2009, 12:40 AM   #75
im thinking about buying a drill press from the local industrial surplus place, and aside from other things, that should be able to handle some p-port drilling so i might say hell with it and experiment.
