Old 01-06-2013, 11:42 PM   #61
Originally Posted by 85turbo12a View Post
thats a matter of opinion, im not impressed at all by cookie cutter builds,
That... we've done close to 40 LS swaps @ Speed1, it's almost gotten to the tpoint where we can flat rate it which is kinda ridiculous. Personally, I'm looking at a few different non RX cars for a unique engine swap but THIS one is definately unique and one of the cleanest that I've ever seen. Well done sir
i dont need that much power so the stock $300 engine with a simple rebuild kit and springs will do just fine, as i would have to do all the other modifications i have done for any other v8, just the initial engine cost would be a lot more as an alum ls2/3 is pretty pricey, so i decided to build something no one else has. and with any luck carve up the dragon with it this year
I would LOVE to see this thing @ DGRR this year, absolutely love to. Good luck with it.... I would offer dyno services, but I fear a 40hr round trip would be a little too far for you
Old 01-07-2013, 12:49 AM   #62
85turbo12a
nerd
85turbo12a's Avatar
85turbo12a is on a distinguished road
thanks dude, im going to try to make the gap...i am trying..
i was there in 2011 and saw your car, its fantastic all the right things in the right places.
appreciate the offer of dyno services, but luckily i have a friend in the biz and he is only 2 miles away so basically have dyno any time i need it.
its good to be da machinist...
85turbo12a is offline   Reply With Quote
Old 01-12-2013, 08:20 PM   #63
85turbo12a
nerd
85turbo12a's Avatar
ok underside is done until further problems surface , car is on the ground and re-wiring for the new engine configuration is under way....not much time till DGRR now...
Old 01-12-2013, 09:15 PM   #64
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
I'm in lovvve! <3 <3 <3
Old 01-13-2013, 10:35 PM   #65
85turbo12a
nerd
85turbo12a's Avatar
rolled it out on its wheels for the first time in a long time and gave it a much deserved bath, i think the corvette is jealous of the attention....
Old 01-14-2013, 04:57 PM   #66
Thanks man, I appreciate that.
Werd.... I wish I was a machinist... I'm still toying with the idea of taking some classes so I can computer design and build some parts that I would love to have....
[IMG]http://sphotos-a.xx.fbcdn.net/hphotos-snc
And probably the HP as well
Old 01-15-2013, 11:29 PM   #67
85turbo12a
nerd
85turbo12a's Avatar
nothing left to show during the ugly and boring wiring process...so stay tuned for the start up videos, good or bad i will post them, if something goes wrong a report will be filed accordingly
Old 01-20-2013, 07:35 PM   #68
fc nut
member
totally insane swap! A++
Old 01-22-2013, 12:06 AM   #69
85turbo12a
nerd
85turbo12a's Avatar
for those who have not seen the insides of it, this is my total black interior conversion with silver and grey trim, silver faced gauges that glow blue, this time around i added a wideband gauge from PLX to match my controller, other than that, its pretty simple and understated like the rest of it.
sadly the previous owner drilled a hole in the perfect dash to mount a ricer tach, so what i did was mount a low profile shift light in its place, filling the hole and not looking too terrible.
Old 01-22-2013, 11:30 PM   #70
730RWHP12A
what turbos are those? i see they are internal wastegate T3 flange, mfg? comp wheel size?
did you arp head stud the motor? head gaskets?
rotaryshack.com
Old 01-23-2013, 12:48 AM   #71
85turbo12a
nerd
85turbo12a's Avatar
sadly my current turbos are of the budget variety, i was using a nice 60-1 turbonetics unit on the rotary, but this project is so expensive i had to get something i could afford at first, they are 57mm compressors, 52mm turbines, .63ar hot sides.
im not asking much out of them so they should behave, and if they dont, i can put garret cartridges in place of the current ones once i recover from the bleeding and have more money.
i did the internal gates because i HATE open dump gates and plumbing a set of externals into the down pipes would make this nightmare of a space problem unbearable lol internals makes it easy and keeps it quiet
i did not stud the engine no, i see no reason to for what i am asking of it, i used stock gaskets, many 1uz have gone in the 10s on unopened high mile blocks, i did use new head bolts and upgraded the springs slightly since i wanted to replace them anyway, didnt cost anything extra to get better ones. i think it upped the seat pressure from like 48lbs to 73lbs if memory serves..somewhere around that.
and i am not looking to go 10s, its just a pump gas fun car. so hopefully it will be ok, otherwise as time goes by i will prep another long block, but building a 1uz with all the goodies in it will run you around $3500 in parts, and that is before you upgrade the cams and the work needed to complete the setup of them, its too expensive, at that point i would just buy an ls2
Old 01-23-2013, 10:24 PM   #72
willnordacgreen1211
willnordacgreen1211 is on a distinguished road
holy shit! just now got caught up on this build, looks fantastic! cant wait to see the burnout video!
willnordacgreen1211 is offline   Reply With Quote
Old 01-30-2013, 09:19 PM   #73
85turbo12a
nerd
85turbo12a's Avatar
trying to figure out how to embed a Facebook video...having no luck
Old 01-30-2013, 10:42 PM   #74
85turbo12a
nerd
85turbo12a's Avatar
http://youtu.be/SXc4Z5otcco
http://youtu.be/BiuHs7mzjLU
testing systems
Old 01-30-2013, 10:52 PM   #75
GySgtFrank
GySgtFrank's Avatar
first link is private. Why you no stick your finger in there on second link?
