Old 02-07-2009, 03:02 AM   #61
Ok, today the koyo radiator, straight pipe, and elctric fan/shroud/relay setup came in:
Old 02-08-2009, 12:33 AM   #62
Ok, so I could not wait untill next weekend, and decided to throw on the exhaust today because we had such nice weather! (i could work outside in my t shirt in central illinois in the middle of feburary!)
Here are some pics:
FROM THIS:
TO THIS!
Hoever, I ran into a bit of a problem. The HKS was SUPER easy to fit on, all the hangers slipped right on, save one that was a bit tricky, but I got it. Then I tried to install my test pipe...
Something is wrong here!!! I pm'd Djmitsu, who donated the item, and he said that it has been measured and fit just fine on several different cars!
So, I took a look at my header, and noticed this funky weld, that looks WAY lower quality than anything that RB would do, and it also does not apear on the other headers I looked at!
Anyway, so that's the story so far... I'm gonna bolt up the stock manifold tomorrow to see if i encounter the same problem.
PS: In case you've been wondering, here's the wiring I've been messing with:
Old 02-12-2009, 08:35 PM   #63
Here is a nice image I found online, and a look I'm going for. I love the stance, offset, and ride height of this vert, is awesome!
Amazingly it is really easy to fit an S4 koyo radiator into an S5 chassis, and it only requires that you purchase the s4 mounts and drill ONE hole! I was worried about having to fabricate new brackets, but it was really simple once I mocked everything up!
Also, on the koyo, at least, the radiator bleed hole is right about level with the thermostat neck, therefore, all my worries about trapped air bubbles are gone as well!
Yay for S4 Koyo w/o the ghey filler neck like the S5 model!
Pics will be up shortly!
Old 03-09-2009, 03:31 PM   #64
So, I got my engine harness redone, with new grounds installed, sections of new wire soldered in, and all the unused emissions plugs trimmed carefully. This is the second time I've done the harness, and it turned out alright, but still a bit off on the lengths. Lesson learned from all this: dont fawk with it if it aint broke!
With some light modding, I managed to fit the Porsche 944 passenger seat(manual rails) to the driver's side FC3S seat rails. The seat is in decent shape, and is a LOT more comfortable than the stock pos. I also got a set of fresher stock seats out of an S4 just in case.
EDIT: No pics of the Koyo because I had to send the Corksport oil lines back, since they kinked and didnt fit right at all. Trying to find some temp lines in the meantime just to get the girl running again, lol.
Old 03-09-2009, 03:44 PM   #65
So, whatever happened with the exhaust issue? have you figured it out yet??
Old 03-09-2009, 03:51 PM   #66
fixing it today actually, just gotta wait for my friend to get here with the welder!
I talked to the guy who sold it to me, and it WAS chopped and welded! I'm taking it of the car, cutting it, and putting in a piece of pipe, then rewelding it shut.
Old 03-09-2009, 05:31 PM   #67
Whew! That is a weight off my back. I didn't want to accidentally derail your project!!
Old 03-09-2009, 08:04 PM   #68
Ok, it's done!
I called my friend, and we went to an exhaust shop, got some free tubing, and grabbed his welder and a chop saw, then it took TWO tries to get the extension perfect! Zach tacked the piece in place, and then welded it using two jackstands as a support. Truck jackstands work really well for exhaust btw!
Here's pics:
That's all, folks!
Old 03-09-2009, 09:31 PM   #69
making good progress!
Old 03-10-2009, 04:03 PM   #70
forgot to post these:
Old 03-19-2009, 05:24 PM   #71
A little something I've been working on. It's a bit ghetto, using sheet metal screws and all, but it was free, and I had fun making it. As far as quality goes, remember, this is just a prototype.
Sneed's Speed Shop Custom Radiator Shroud.
Thermostat, relay, 30A fuse, and a switch so I can turn it on manually just in case.
Porsche 944 Passenger Seat (manual adjusting rails) bolted up to the FC seat rails. I needed to extend the holes a bit, but otherwise it bolted right up!
S4 Cloth seats I got from a friend:
Old 03-19-2009, 08:21 PM   #72
Max........
Technically, you have an FC3C....not an FC3S......
But anyway! Making progress, good stuff!
Don't forget, DGRR is a month away, and you said you would come! If I can rebuild a Miata in a month, you can finish this bitch!
DO IT!!
Old 03-19-2009, 08:54 PM   #73
well double technically he has an FC35. Most others have an FC33.
Old 03-20-2009, 12:06 AM   #74
i WILL DO IT!
Just got to get those effin oil cooler lines in, floor welded, and stereo installed. After that, if it doesnt blow up, I will put insurance back on it, and drive the bitch to DGRR!
hopefully, nopistons will go with me, but I dont know if we can finish two cars by april.
PS: FC3S sounds cooler!
Old 03-20-2009, 01:57 AM   #75
Nopis1O
Nopis1O's Avatar
Nopis1O is on a distinguished road
Thumbs down
Originally Posted by Max777 View Post
i WILL DO IT!
ha you worry about yours and let me worry about mine. as far as geting it done by april i might have it running and primed but not painted and interior done. even still i cant get off work i dont think so not this year but deff next year!!
OH and you get free seats, dash, suspension, ect and no where in this thread am i thanked by name. i see.
1988 Fc Vert. Super Stock
1990 Fc Hard top: Brideported 13b, weber carb, 350z wheels w/nitrogen, or 16in BBS meshies, Msd, Racaro Racing Seats, Custom Gauge cluster, custom Intake, Relocated Battery, 3inch header back borla exhaust system, Alpine stereo system, Wire tucked, S4 shift boot&knob, custom Strut bar, And soon to come a Full black w/ gold pearl paint job, powder coated break calipers, all black interior, bride headliner/door panels.
Nopis1O is offline   Reply With Quote
