| 20B/3 Rotor Conversion.. All things to do with 20B/3 rotor... Post pics, video, tech, etc.. |
#1 |
WNC Tour Guide
Rep Power: 18 ![]() |
they modify the back of the stock 20B oil pan to clear the FD subframe (and decreasing oil capacity. They do not do any modifications to the front of the oil pan where the sump tube is. and from my previous experiences of doing business with them, I would rather just not deal with them again.
My plan is to leave the stock oil pan unmodified and to cut my subframe and modify it to fit around the 20B pan. really it's just cutting out one section and welding a new cross bar further back... i probably should do this before i re-install the front lower control arms... since i have to swap out subframes anyway...
#2 |
500hp club
Rep Power: 15 ![]() |
Either way you do it your gonna have to fabricate. Best to mod the oil pan unless you really know what your doing with the subframe.
Since I moved my engine back 3" I made a custom subframe and oil pan And if you decide to modify the steering rack mounting in any way make sure you dont have any bump steer with the final product.
500hp AEM EMS RotaryAutomotive street ported Aviation sealed 13b-rew 20B 20BEEST FD 23A 4 rotor Long gone 72 rx3 drag machine |
#3 |
WNC Tour Guide
i did modify a stock subframe. I simply cut out the rear "cross bar" and replaced it with a smaller bit of square stock. i'll snap some pics while the engine is out for the car to get the bay painted...
so, this past weekend I was able to get the engine test fit again with the modified subframe, depowered steering rack, stock 20B oil pan (with banzai racing oil ban brace), exhaust, trans, and intake setup. now everything clears a stock hood... without the fancy air box... so i'm running open trumpets and need to figure out filters for them. At this time, the car is stilling with a full drive train except for drive shaft and powerplant frame. one thing to note are that the header barely touches the subframe so when i pull the engine off and before the car is sent off to get the bay painted, I'll need to do a little massaging of this area. need to just notch it to clear more. otherwise, i'm happy with the clearance the steering rack has below the engine... and if i wanted about another 1/5'' of clearance from the hood, I could get some 2.4'' tall engine mounts (instead of the 2.6'' I have now) And dropping the engine lower would definitely require me notching for the header on the subframe. I'm also having to look at other options if i want to run a front strut tower bar, the one that came with the car doesn't clear the trumpets. as before, next steps:
![]() 11 pics added to the album
#4 |
Waffles - hmmm good
Rep Power: 0 ![]() |
You know you can't keep using the id lt1_fd3s once this is done, right? I mean
you will now be 3rtr_fd3s or something. Or just poor! Looks like progress, anyway you look at it. DGRR 2016 for it?
1980 GS stockport, Fat Nikki, RB Dual Facetfuel pumps, Holley regulator, RB Street port exhaust, 2GDFIS, MR2 MK I electric fans, 2G strut bar, relayed fans, lights and fuel pump, LEDs Project Fat Nikki Budget 12A rebuild Video setup < $30.00 |
#5 |
Rep Power: 16 ![]() |
I like your scooter. Its a good size for you
-75 RE_W_PU - -76 Hercules W2000 - DGRR 2012 3rd place Old School -75 Hercules W2000 MSO - DGRR 2011 Peoples Choice - April 2011 Rotary of the Month ![]() -Rotary snowmobile powered go kart - DGRR 2012 Peoples Choice - RIP |
#6 |
WNC Tour Guide
might have to see about getting my id changed to 20b_fd3s or something after she's done...
#7 |
Rotary Non-conformist
looking good will be looking for it
#8 |
Home-brew Rotary
How's this project coming along?
Will it be making an appearance at DGRR?
'89 RX7 GTU, half-Bridge-port S4/S5 NA, E6K, Full RB exhaust, weekend warrior. '83 RX7, The "this might take awhile" project. '87 RX7 GXL, Rest In Pieces. '98 Subaru Impreza Outback-sport, rx7 rescue vehicle, down for repair. '94 Ford Ranger, daily. |
#9 |
Yea Tray....we need an update....anxious to see it with new paint.
#10 |
WNC Tour Guide
it finally ran last night
#11 | |
#12 |
Waffles - hmmm good
Nice! Sounds good too! Can't wait to see it.
#13 |
Rep Power: 20 ![]() |
I cant wait to see it either! I'm guessing it'll be at B3R?
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
#14 |
WNC Tour Guide
i do hope so!
| Bookmarks |
