Old 10-03-2016, 08:48 AM   #1
Fix yer pics son!
Old 10-03-2016, 09:02 AM   #2
Damn.... some good parts in there. Nice find
Old 10-03-2016, 09:03 AM   #3
Fix yer pics son!
Google derp'd on me.
Yeah, this engine I didn't have alot of hope for, but wouldn't you know, it's essentially PERFECT!!
Old 10-03-2016, 09:31 AM   #4
Yeah.... That's amazeballs
So you're roadtrip to the NE?
Old 10-10-2016, 08:44 AM   #5
This fucker just refuses to be resurrected.
Jeff, Paul, Charles and I dropped in the 13B 4port that was rebuilt for the silver Cosmo, and the 5 speed box. Everything went smooth, only real hiccup was the carb needed a little extra love. She fired right up.
Then, about 10 minutes in, she started pushing coolant into the overflow. Used a cooling pressure tester and pumped it up to see what's what.
17 psi held bled down to about 16 psi over an hour.
Removed Leading plugs. Pumped it up to 20 psi. Bled down to about 16 psi in 20 minutes.
Dammit.
I did swap in a good brake master cylinder though, so when it does run, it should also stop.
Sigh.
Old 10-10-2016, 08:58 AM   #6
Did you turn the engine over to see if it didn't just leak air out somewhere?
Old 10-10-2016, 09:03 AM   #7
Yeah. I had Myles on chat to help me run through some tests. I think we're going to haul it to Charles house to do more diag, then last resort, pull the motor and see what's what.
Old 10-10-2016, 09:10 AM   #8
Damn rotaries.
I still say keep the engine, and gimme the car
Old 11-12-2016, 11:44 AM   #9
Guess I should update, in case anyone is reading.
Seized T-stat turned out to be the culprit as far as cooling is concerned. FIXED
When bleeding the brakes, I noticed the right rear caliper was not 'bleeding' as well as the others. That is also the ONLY caliper I did not replace the hose on. So, I'll do that today. (also, that same caliper bracket was finger tight. sue me)
Still have been unable to find an e-fan that fits the shallow space between the rad and pulley, so I am putting a clutched fan back on. The original is seized, but Charles has many to choose from. Going over there later to pick one out.
I have the adapter for the back of the WP housing for my temp gauge, and the oil pressure gauge is already plumbed. I am removing the wicked 70's awesome Audiovox 25 amp SOUND BLASTER from the dash pocket and putting my gauges there.
Also, Charles and Jeff worked some magic on the exhaust and have it hanging PERFECT. New hangers helped immensely.
It needs an alignment pretty bad. And there is a knock over bumps and stuff. We'll check out the ball joints (I have spares) and the sway bar links (Also have spares) when I swap wheels. I decided I am not a fan of the Diamond Racing steelies, since they are so damn heavy and not hub centric. Adler removed the awesome Sears Roadhandler tires circa 1985, and I'll be getting something in a 205-60-14 to replace them. Charles is buying the Kuhmos from me, and now I'm stuck with a set of rims that don't fit anything else. Hooray.
I also swapped hoods and trunklid from the Silver car, as they are in far better shape until we can repair rust on the underside of the white pieces.
Pic for the lames.
Old 11-13-2016, 08:07 AM   #10
FC Zach
FC Zach's Avatar
Do your wheels not have tapered lug nut seats? Are you using the incorrect lug nuts? Whats wrong with lug centric?
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 11-12-2016, 12:40 PM   #11
rx7 vinnie
I SEE DEAD PEOPLE
rx7 vinnie's Avatar
Oil leak on driveway gives a rotary owner away.
03 Dodge Viper SRT-10 Vert
16 MB ML350
Old 11-12-2016, 01:37 PM   #12
Kinda. That was mostly coolant after the t-stat replacement. Although there was a slight leak from the drain plug (not my fault) as well. Doesn't leak anything, anymore.
For now.
Old 11-12-2016, 01:45 PM   #13
rx7 vinnie
I SEE DEAD PEOPLE
rx7 vinnie's Avatar
Word. Wish I cared enough about my cars to work on them. Kudos
16 MB ML350
Old 11-12-2016, 01:58 PM   #14
Stop being lazy. This is a resurrection of a long dead Mazda found in the boonies. It has been frustrating and rewarding to get ONE of these Cosmos running and driving finally. It would have been done WAY sooner if baby #2 hadn't destroyed my free time and bank account.
Old 11-13-2016, 10:32 AM   #15
Jeff was concerned, even though the wheels are lug centric. And Jefe is the expert.
