#46 |
Rep Power: 21 ![]() |
Yea i will use an FB axle in the rear and that will match the front. And wicked flares Are a must!
Right now its mounted using stock fc mounts. Might have to consider seatig position with how its turning out. The oil filter would be in your shin stock wise
For current updates and event coverage check out Follow on Twitter! @WhizbangRally Whizbang Rally's Webpage | Facebook |
#47 | |
Professional Stick Poker
Rep Power: 16 ![]() |
![]() That does sound a little far back. How did you get it in there? Remove the firewall?
1988 N/A SE 2+2, dead stock and staying that way. ![]() 1979 SA22C stock? Not so much. http://rotarycarclub.com/rotary_foru...ad.php?t=15585 Last edited by GySgtFrank; 08-08-2013 at 09:14 PM. |
#48 |
Ive been using gslse stuff. Gets about an extra 20mm.
Yea trimming was required
#49 |
Car is now in california. Next step will include coilovers and rx7 axle mit four link
#50 |
idahorotary.com
So you in Cali now?
Come visit us if you are ever in the area.
87 TII-E85-600+ RWHP and climbing Life starts at 2 bar! Come visit my forum! idahorotary.com http://idahorotary.com/smf/index.php |
#52 |
Well hanging out for a couple weeks then officially In CA
Yea needs eiter 14s or a smaller tire or both
#53 |
Just properly sized wheel openings on the custom widebody you're going to have to build. 'cuz you need moar tire.
1988 N/A SE 2+2, dead stock and staying that way. ![]() 1979 SA22C stock? Not so much. http://rotarycarclub.com/rotary_foru...ad.php?t=15585 |
#54 |
indeed. I am thinking about taking a class on how to use the "english wheel" and build my own sheel metal flares.
#55 | |
![]() Just have to setup the wheel arches to follow the chosen size 15" tire that you'll be using.
#56 | |
Rep Power: 18 ![]() |
Also motorcycle fenders cut in half?
#57 |
Yup a lot like that Frank. Just not sure on on wide to go. Need to find the wwheels i want to use
#58 | |
These?
This can also be done by cutting a radius in the stock flare. Pull open gap to desired flare. Fill in the gap...
#59 |
Eh more buldge on the top though i think. I will have to find a picture
#60 | |
Something round? This is for a 16in wheel they also have a full round wide fender.
| Bookmarks |
