Old 07-21-2009, 04:12 PM   #31
I think he meant 1oz:1gal (which is what I ran for a while until it started fouling up my plugs)
Old 07-21-2009, 08:18 PM   #32
Originally Posted by Zenki7 View Post
Go to Corbincorp.com
Order this part # 48701031 through MSC, which is the tubing make sure as the quantity you put it in as it were feet.... I ordered 10 in quantity therefore I got 10 feet. I did this just incase I screwed up something!
The clamps are part number 48547962 they are two ear clamps.
Simply remove your lines and keep track of where each banjo came from.
Does it matter which line you run to which location? Aren't they all fed the same amount.
Old 07-21-2009, 08:52 PM   #33
What kind of crap oil are you guys using? I run my O/B @ 50:1 and the plugs don't foul. Although that engine gets run at two speeds, idle or WOT. But then again when I was mixing that same oil 1:128 in the tank AND running the OMP, the plugs weren't really fouling either.
So, what brands are you guys using?
Old 07-21-2009, 10:18 PM   #34
project86
Can't.Make.Up.My.Mind.
project86's Avatar
im using amsoil
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
