Old 12-22-2008, 02:44 AM   #31
Fidelity101
Reliable Source
Fidelity101's Avatar
I'm surprised it took this many pages, anyways when in Rome!
My Rx-7 Vids
Old 12-22-2008, 02:57 AM   #32
How did the trans crossmember come out? I have a TII swapped FB with a kinda modified stock crossmember that sucks...Wouldn't be interested in making a copy would ya? wink wink
As far as driveshaft, I just had a local shop in Nashville make me a 3" shaft with spicer joints for around $300.
Old 12-22-2008, 08:50 AM   #33
staticpat
Rally Fanboy
staticpat's Avatar
staticpat is on a distinguished road
The problem with the driveshaft is I don't have a T2 yoke, and I don't want to buy a T2 driveshaft just to cut it up. Mazdatrix said they'd make one I just need to get my measurements.
The tranny mount is still in progress. I'll get some pics of it and see if we could make an extra one.
staticpat is offline   Reply With Quote
Old 12-22-2008, 11:05 AM   #34
The shop I used is Clinard's in Nashville and when they made mine, they had two TII yolks so I paid for one and he let me take it home and used it to get the measurements, then I called him with the measurement and he built it for me and I just brought back the TII yolk and swapped it for the new driveshaft
Old 12-22-2008, 11:54 AM   #35
Fidelity101
Reliable Source
yeah so then they can sell the driveshaft to other people with the same situation your in, FB body with TII trans.
cash money, dolla dolla billz yall.
My Rx-7 Vids
Old 01-04-2009, 07:41 PM   #36
staticpat
Rally Fanboy
staticpat's Avatar
Worked on cleaning up my wiring and stuff the last couple weeks. I also installed an electric fan. I did a pusher setup since I had lots of space in front of the radiator.
The motor as it sits.
Here's a bad picture of the battery relocation. I ran the (+) to a cutoff switch in the rear. I also put a breaker in the engine bay where the fuse block terminates. Later when I'm sure of the regulations I will add another cutoff switch within arms reach of the driver.
I also got a friend of mine to start making something to fill in the gray. We are going to work on some rotor stencils (speedsource style, but not knockoffs) to fill in the rest. May or may not do a hood graphic.
Old 01-04-2009, 08:19 PM   #37
Fidelity101
Reliable Source
You should go double alt pulley to prevent water pump slippage.
My Rx-7 Vids
Old 02-14-2009, 05:12 PM   #38
staticpat
Rally Fanboy
staticpat's Avatar
I haven't worked on it much lately, I was waiting for my driveshaft. Anyways it got here so here's some updates.
Biggest thing is obviously the trans mount for the T2 trans and driveshaft. No Limit built me a mount, and I finally got a custom driveshaft in from Mazdatrix (took forever :< ).
I fixed up a few things in the engine bay. I cleaned up all the wiring and got rid of all the excess crap. I also installed different plug wires, double alternator pulley, fan relay, and a K&N filter kit for the carb.
I did some little things here and there. Installed 2 of my 4 new pedals from autovation. These are actually made for heel/toeing they aren't entirely rice parts.
I finished my battery relocation. Got a tiedown welded to the frame and have a marine box for regulations.
The next big thing I'm playing with is the suspension. I'd like to get the car low for auto-x and track days, but be able to raise it up for sweet rally action. I got the RE-Speed coilover kit for the front and rears. After talking with Billy I picked some custom spring rates and lengths. I opted for 10" long springs. Going by recommendations on specialstage I went with 225# fronts, and 125# rears. The softer rears will supposedly squat better for more traction in the dirt. We will see how this works.
The first pic shows the wheel gap in the back, lowest setting on 10" springs. I also have a set of 8" I'll keep for track days. Still working on the getting the fronts fitted.
The beast as it sits, waiting one day to drive.
Next things up are finishing the front suspension, new front sway, steering wheel, and a T2 shifter. We also found out there may be fuel delivery problems. I bought an inline pump, but I don't really want to install it yet. We'll see if some troubleshooting can get me running soon.
Old 02-14-2009, 05:20 PM   #39
yea for progress! Do you have your brake lines run in the cabin and fuel lines protected?
Old 02-14-2009, 05:29 PM   #40
staticpat
Rally Fanboy
staticpat's Avatar
Nah, there's still lots to do if I actually want to run stage rally.
When I put in a new pump I'm probably going to run all the lines inside. I believe this is legal (and preferred) as long as no joints are inside the cabin.
Old 02-14-2009, 05:36 PM   #41
staticpat
Rally Fanboy
staticpat's Avatar
Oh I forgot something slightly important. Our first local rallycross was last week. Since my car is disabled I got to drive a Focus.
The cool thing was it was at a speedway with a dirt circle track. The organizer invited all the dirt track guys to come run for free. With enough support he is going to try and organize a European style Rallycross. For any not familiar this is door to door racing through left and right turns on both tarmac and gravel.
His goal is to get some rules set so the dirt trackers and rallycrossers can both run. He wants to have 4 cars on a mixed gravel/tarmac course at a time. Some safety regulations will obviously have to be worked out. If this is a go, then I am definitely building my car to compete.
Here's some rallycross pics for fun. No shots of the Focus though :<
Old 02-16-2009, 05:22 PM   #42
warwickben
sa rat rod
i really want to get into rallycross. can you point me to a web site telling me what ill need to do to the car to pass spec ect.
Old 02-16-2009, 06:22 PM   #43
scca website has the rules
Old 02-28-2009, 11:00 PM   #44
BMW.Nick
BMW.Nick is on a distinguished road
Man it's so cool to see Gregs old car getting all that attention! We went and picked that thing up in TN for $1800 with 160k on it back around '98-99 and it NEVER let him down! I can even tell you how it got dented on the drivers side...
I used to live in some Condos in Vestavia at the top of a hill. Greg parked on the curb out front and came inside...we went back out after hearing a crash and found Gregs car at the botom of the hill attached to a Volvo!! Detroyed the fender and jacked the door up.
That was a great car and Im glad to see it back to life like this!!
2006 BMW X3 3.0i
2006 VW GTI
1985 RX7 GS project
BMW.Nick is offline   Reply With Quote
Old 03-03-2009, 09:07 PM   #45
staticpat
Rally Fanboy
staticpat's Avatar
For anyone keeping track there is a minor update. Today Todd at No Limit and Phil (Herblenny) helped get the motor running.
It ran like a top until the coolant system over-pressurized and decided to release said pressure all over my face, the car, and the shop. Also a wire caught fire. Also my radiator apparently split open. Also I need a new battery. Oh yeah, I need the coolant seals replaced too. So a couple minor things and it should be good.
