Closed Thread
Old 05-28-2015, 04:33 PM   #1
JL1RX7
When is the first fire up? Looks like you are moving right along.
JL1RX7 is offline
Old 05-28-2015, 05:31 PM   #2
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Not sure yet. Depends on whether I go fuel injected or just use the 45DCOE I have. The Weber would be a lot faster, wiring wise, but then I have to use my points style 12A distributor and figure out the wiring for that. I like the way the fuel injection works though and keeping everything stock FC eliminates a lot of tuning hassles down the road.
Working on transmission mount now. I stole the poly T-5 trans mount I had for a 5.0 Mustang and am adapting that. It is actually fitting fairly close and is only requiring minor modifications to fit. The T-5 mount is quite tall for most uses, but should work fine in this application, I think.
GySgtFrank is offline
Old 06-03-2015, 03:00 PM   #3
GySgtFrank
GySgtFrank's Avatar
Working on transmission mount.
I cut out the original fixed transmission crossmember as it makes getting the engine in and out a royal pain. The problem with cutting it out is that there is nothing to bolt a replacement to. The crossmember is only boxed light sheet metal and is insufficient for bolting a heavier gauge center section to. My solution was to use 2 3/8ths outside square tubing, which slid into the stubs nice and snug. Finding that size tubing is a bit of a bother, but it works perfectly. I then used 1/2" bolts to fasten it within the frame rails. Capped off the ends with some 3/8ths plate and welded nuts inside for both the facing plate and the frame fasteners.
trans cross member attachment point 2 by Kevin Frank, on Flickr
trans cross member attachment point 1 by Kevin Frank, on Flickr
There will be a 2" wide (1/4" plate) strip bolted underneath, as part of the center section, with the rest of the center section bolted both below and to the sides. I planned it like this so that I wouldn't be hanging the mount from something that the bolts were in shear.
more pics when I get that done.
Old 06-05-2015, 05:26 PM   #4
GySgtFrank
GySgtFrank's Avatar
One transmission crossmember; done.
I have to wait for the paint to dry then I can re-install it and post a picture of it installed, with the transmission sitting on it, tomorrow.
new transmission crossmember by Kevin Frank, on Flickr
Old 06-05-2015, 06:44 PM   #5
diabolical1
I have radioactive semen
as always, i'm quite impressed with your work. i think if you already have the Weber setup in hand, then you should use it. you could always take the EFI road later on. besides, it would give you a jump on ironing out some wrinkles before the EFI wiring headaches.
diabolical1 is offline
Old 06-05-2015, 06:56 PM   #6
GySgtFrank
GySgtFrank's Avatar
I have the carburetor, but not the manifold. The carburetor would also need extensive re-jetting as it currently has 36mm chokes which would have to be changed out for 40s, along with the emulsion tubes, idle and main jets, etc.
I keep waffling back and forth on it. I will have to see when I try to re-fit my hood (bonnet for Brian) with the engine in there. If it doesn't fit with the EFI upper, which is what I've been told, then I'll definitely be using the Weber.
This car has made me want to join you in that bottle of Glenfiddich on a great many occasions.
Old 06-05-2015, 07:25 PM   #7
diabolical1
ahhh ... understood. it's not complete. although, it also sounds like the writing is on the wall, so to speak.
understood again ... completely.
Old 06-06-2015, 10:31 AM   #8
GySgtFrank
GySgtFrank's Avatar
As promised. Pictures of the finished transmission crossmember installed.
trans crossmember - new - installed by Kevin Frank, on Flickr
I couldn't get the bottom rear side bolts in, there just isn't enough room to get a wrench in the limited space to tighten them. It should be fine with three 7/16ths bolts per side though. Quite often things don't quite work out the way I intended.
While under the car I took a shot of the frame modification I did for the starter. The starter had me worried, but it fit fine. The only problem was having enough room to get it out without having to pull the engine to do it. I considered that to be what you would call a "bad" thing. So I laid the frame rail back a bit and plan to bend and weld in a piece of 1/8th inch plate to reinforce that spot while leaving me enough room to service the starter when it needs it.
starter frame relief by Kevin Frank, on Flickr
Old 06-06-2015, 11:29 PM   #9
GySgtFrank
GySgtFrank's Avatar
It fits!!!! :snoopy happy dance:
13B final position by Kevin Frank, on Flickr
The hood closes with the EFI manifold on the engine.
I have about 1/2" of clearance at the closest point from the top front edge of the manifold to the underside of the hood. Even the filler neck for the coolant fits with plenty of clearance. This is rather astonishing to me. I figured and measured and planned it out to get the engine low enough for it to go in there. I'm actually about two inches lower than I have seen anyone else set the engine in one of these. That two inches was a LOT of work to get though. When you're juggling as many variables as there are in locating an engine in a space this small I've come to expect things not to quite work out right. I's a happy camper right now.
I did have to trim a little more than I expected from the passenger foot well though. I don't think that it will be a problem with where it's at, but if anyone complains I'll just punch it and they'll be so busy hanging on they will forget all about it.
Old 06-06-2015, 11:36 PM   #10
chibikougan
chibikougan's Avatar
Schweet!
chibikougan is offline
Old 06-07-2015, 12:29 AM   #11
GySgtFrank
GySgtFrank's Avatar
Schweet!
Thanks. Oh yes it is! Getting that S4 EFI manifold to fit under the hood was one of my biggest hurdles when planning out this swap.
Old 06-07-2015, 12:49 AM   #12
chibikougan
It is a plus having an engine that fits under the bonnet..
Old 06-07-2015, 06:12 AM   #13
Nice work Gunny! I'd give you grief and tell you to slap a turbo on it, but after seeing how little room you have to work with in that last picture, I'll just keep my yap shut!
Pete_89T2 is offline
Old 06-08-2015, 10:54 PM   #14
GySgtFrank
GySgtFrank's Avatar
So this is what I spent an entire day doing. Just one little piece of tube, that's all. Right!
13B header 1 by 13B header 2 by Kevin Frank, on Flickr
well besides the tube, I did get the O2 sensor bung welded in, so that's two things I guess.
I am modifying the Racing Beat 6 port header, that I already had, to fit in the midget. It will have to be a two piece design if I am to have any hope of ever getting it in and out of the car. This is the upper portion mating to a road race outlet flange. It will be mated to a lower section using the same type of flange and making an immediate 90 straight back. Needless to say there was lots of fiddling to get it just right so that everything would go where it needs to. Now that I have a better idea of what I will need, I ordered some more flanges, bends, and straight tube from Racing Beat to finish part of the exhaust system.
Old 06-09-2015, 05:33 PM   #15
GySgtFrank
GySgtFrank's Avatar
S4 specific Six port actuator tube installed. Has to be at just the right angle and spacing to make it possible to still slide the header out of there.
13B header six port actuator tube by [url=https://www
Closed Thread
