Old 06-03-2013, 08:37 PM   #1
Whizbang's GSLSE
picked this up for a few hundred since the audi is being sold. ran rough, didnt want to start unless i poured gas on the filter, and had some low oil pressure. The engine is an S4 motor, recently swapped, and poorly. moving the distributor didnt change anything. sounds different than a one rotor situation, engine had even strong "poofs", and it has no power.
i think the low oil pressure is the front cover o-ring going to be taking a peek here this week.
I got all the S4 ecu, wiring, and sensor bits to just run the S4 stuff in an attempt to get the car running right. Began the process of making the S4 wiring harness ready for install... (hence the pile of wiring)
